Old 10-12-2011, 06:52 PM   #1
JEFF BARTON's Avatar
Power to tt with 7 pin
Should i have power to my tt rockwood 8313ss when it is hooked up to my truck with the 7 pin trailer harness ? I took the battery out does that make a difference? 2001 f150 5.4 or is it my truck wiring? It is a older truck help.
JEFF BARTON is offline   Reply With Quote
Old 10-12-2011, 07:39 PM   #2
bikendan's Avatar
Nope! Not without a battery. Your pigtail will barely supply more than a trickle charge to the battery.
Old 10-12-2011, 09:52 PM   #3
On a 2001 F150, in order to get power to the trailer, the key must be in the "on" position. There is a relay, under the hood fuse box, that supplies power when the key is on.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 10-13-2011, 07:16 AM   #4
frankm's Avatar
Originally Posted by windrider View Post
On a 2001 F150....There is a relay, under the hood fuse box, that supplies power when the key is on.
Check that the relay is actually installed. I have had two F-150s, a 1997 and a 2008, both new from factory. In both trucks that relay (and a couple of misc cables) came in a plastic bag in the glove box!
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 10-13-2011, 09:40 AM   #5
TURBS's Avatar
normally that relay does not come in the fuse/relay center
even though it has tow package .
you have to install it !
