Old 10-14-2015, 10:13 AM   #1
TURBS's Avatar
Progressive ems hardwired "HUM"
In speaking with a progressive industries tech today about my 30 amp hardwired ems, I asked him about a hum some people have commented or complained about.
He said that's a "60 hertz" hum and can be almost totally eliminated by installing rubber washers under the four mounting points of the case which he recommended if your unit hums or not as the unit should have air space under it to keep it cooler but not necessary if unit cannot be raised off the floor.
Just an fyi.
TURBS
08 duramax tuned n modded
2015 columbus 320RS
2015 camping "30 nights"
Old 10-14-2015, 10:15 AM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
Good tip. Do you ever work? Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 10-14-2015, 10:27 AM   #3
Iwannacamp's Avatar
I thought of this too. Mine hums too...I just blamed it on being mounted on cardboard...I mean an interior wall. Thanks
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 10-14-2015, 10:31 AM   #4
CCRVOC
Ramblin Recks's Avatar
Yes, I used rubber grommets for the "feet" when I secured it to the floor.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 10-14-2015, 11:16 AM   #5
TURBS's Avatar
No.
TURBS
2015 columbus 320RS
Old 10-14-2015, 11:16 AM   #6
TURBS's Avatar
Gentlemen suggested 1/2" thick rubber spacers.
TURBS
2015 columbus 320RS
Old 10-14-2015, 11:25 AM   #7
Thanks for giving me another project. (sarcasm)
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 10-14-2015, 11:26 AM   #8
TURBS's Avatar
"Sarcasm" dually noted!
TURBS
2015 columbus 320RS
Old 10-14-2015, 11:52 AM   #9
Evereddie's Avatar
On the EMS unit and my water pump I use rubber washers under the feet and under the screw head. I make the hole on the feet bigger so that the screw going through the feet does not touch the sides of the hole in the feet This gives total isolation and the noise transference goes WAY down. If you don't use rubber under the screw head the screw will touch the unit case and still transfer noise to the trailer.
There are fancy grommets you can buy that will take care of both sides of a foot. Something like this: http://www.armadarubber.com/isolation.html
Maybe as an option Progressive Industries could offer rubber isolators in the feet as an option.
Evereddie is online now   Reply With Quote
Old 10-14-2015, 12:31 PM   #10
Ashley's Avatar
Progressive EMS 30 Amp Hard Wired Hum Experience
Just an fyi.
TURBS
2015 columbus 320RS
A while back I was one of the people who had asked you about it through a private message. I had just installed mine and it was humming like crazy. I called Progressive and the tech told me it was most likely due to the contacts in the contactor not making one hundred percent connection due to the cosmoline protectant they utilize during manufacturing to prevent corrosion before use. He told me to turn on as many loads as I could in the RV, then cycle my breaker at my power post panel numerous times allowing the contactor to actuate and each time it did so the heat from the arc would burn off the excess cosmoline and resolve the problem. He was correct in my situation, as after about a dozen times the hum was gone.
I could feel the vibration so strong before that it was traveling down the romex wire several feet that came out of the EMS and went to the power convertor. I had even installed extra wiring hold downs and tried the rubber under the mounting area of the EMS.
This may not be everyone's issue, but on new installations where the unit has not cycled off and on some it may very well be. Just wanted to pass along my personal experience in hopes it will help someone down the road.
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
Ashley is offline   Reply With Quote
