Old 03-21-2014, 02:50 PM   #11
I installed the 50 amp version a couple of weeks ago and if was to do it again I would have spent the money on the plugs. It would have been easier to make the connections to the unit with the plug pig tails on the table then simple place the unit into the final location and plug in the plugs. I was in a hurry and I bet it took me two to three times longer to install the unit with out the plugs. Live and learn I guess. My thoughts now are if I need to remove it for any reason I will redo the wiring and add the plugs at that time. The plugs are really a great idea.
Thanks Turbs!
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
MMattox is offline   Reply With Quote
Old 03-21-2014, 03:42 PM   #12
HONDAMAN174's Avatar
Don't know if this will help for your install- my power cord in was located in a storage area so I just put it there. Gave me lots of space to work around.
Just glad to get away
Old 03-21-2014, 03:58 PM   #13
hihocarp's Avatar
UPS is a bugger for adding brokerage fees to the shipping costs when ever I order something out of the US. My Airlift air bags cost me an additional $91.00 before MR UPS guy would give me my package. One way to get around the extra charges is to ask to have your package shipped USPS. I've never had to pay any extra whenever I use the mail system although it may take longer.
2012 Dodge Ram 3500 Crew Cab Dually
2015 Columbus 365 RL ( completed April 14,2014 )
Baxter and Bella [our dogs]
Days camped in 2014: 7
hihocarp is offline   Reply With Quote
Old 03-21-2014, 04:39 PM   #14
The connectors are a great idea, but I did what you did and mounted the protector in a storage box next to my power cord. I actually opened up the junction box that housed the end of my power cord and the orange coach main and joined them using the surge protector. If for any reason the device fails or I sell the coach I will just re connect everything via the factory junction box.
Kf4mnc is offline   Reply With Quote
Old 03-21-2014, 04:41 PM   #15
Exactly!
Old 03-23-2014, 07:35 AM   #16
Wanna Be Camper
SaskCampers's Avatar
I always ask any place I buy stuff from in the US if the will ship USPS. If they don't I look elsewhere for just that reason as UPS are just a bunch of legalized thieves IMO. I have had things as large as exhaust pipes for my old Hyundai sent usps no issue. I have my EMS mounted directly behind the converter and have run the monitor cable up through the space under the false bottom of the upper kitchen cabinets and the monitor is at the top of our FR control panel. I used 3M removable sticky stuff to hold the monitor and the wire just comes out from the control panel hole so it can be removed with no sigh it was ever there.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 05-08-2014, 09:32 PM   #17
Does anyone owning a sunseeker know where I would start to hardware a surge in?
Where does the outside wire run to?
Pacostaco is offline   Reply With Quote
Old 05-09-2014, 02:40 AM   #18
hihocarp's Avatar
The main power would run to the breaker panel. I just wired in my surge protector today on our Columbus and that's where I hooked into. I bought 3 feet of 6/3 cable, disconnected the 3 wires and ground from the panel which I ran into the protector then used the 3' new cable to come out of the protector and back into the breaker panel. Was pretty easy other than wrestling with the heavy gauge wire. Mine is 50 amp by the way.
