09-11-2015, 01:14 PM
#21
Left Coast
Originally Posted by SuicideSaints
It could be the Genny is not up to the task or you need a "Ground-Neutral Bond” jumper plug (edison plug).
Falling on def ears...
09-11-2015, 01:16 PM
#22
My Honda 2000 runs with the EMS 30 hardwired just fine. Voltage is always between 116-124 depending on load. If I want to run the 15K A/C, I parallel two Honda 2000s together with good results. As you mentioned, I had to make a ground to neutral connector for the Honda in order for the EMS to play well with the Hondas.
Alternatively, you can switch off the EMS power management and just make it a surge protector via the remote switch (not recommended). This supplies power to your converter without the need for a ground/neutral adapter on the genny.
I suspect that your genny is dropping voltage on load and the EMS is doing its job.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
09-11-2015, 01:19 PM
#23
Left Coast
Originally Posted by aceinspp
Honda does not recommend running an AC with the 2000. Good way to ruin AC. Later RJD
How many amps do you think a 13,500 a/c draws? 12...
09-11-2015, 01:36 PM
#24
Who Dares, Wins
Think it's 12 to 14 on start up and 8 or so just running. I can do it in one honda 2000 with the hard start capacitor and nothing else on. Once I try the thing with the converter or fridge it overloads.
Not sure about the generac but the 2000 on the Honda is a surge wattage.
The ac will trip it if I kept the economy throttle on, maybe try running your stuff with the economy throttle off if you have it and see if it keeps the voltage.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
09-11-2015, 01:57 PM
#25
Left Coast
Just plugged one Honda in....not using eco. I have a 3 amp draw before starting gen...refer is on....Running, adding a/c, shows 16 amps....no problem running....when camping, I use both.
09-11-2015, 02:34 PM
#26
I had a similar problem and called Progressive. Their customer service is outstanding! I believe your problem is the need for a neurtral ground bond on the inverter/generator. Without going into great detail it is a plug that allows you to use your inverter/generator with a Progressive EMS. Progressive will give you instructions.
2015 Crusader 315RST
2011 Silverado 2500HD
09-11-2015, 03:04 PM
#27
Left Coast
Get a normal 15/20 120 3prong plug...looking at prong end of plug, add a 14or16 gauge wire from ground terminal to prong on left side....of course, do this on inside of plug. plug into gen...done.
09-11-2015, 03:20 PM
#28
This site will explain the N-G Bond plug and how to make it...
Generator Ground-Neutral Bonding | No~Shock~Zone
2016 Ford F-150 4x4 Supercab XLT EcoBoost
2012 Salem Cruise Lite 221RBXL, Andersen No Sway WDH, (2) Honda EU2000i's
09-11-2015, 04:30 PM
#29
Left Coast
What I just posted
09-11-2015, 05:09 PM
#30
Dometic recommends at least a 3500 watt generator.
It's right in there owners manual
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
09-11-2015, 05:14 PM
#31
I have a 3K Yamaha inverter generator, I too bought the 50 amp portable protector..When I read the destructions, it said not to plug the protector into an invertor source.. I told them that I had the Yamaha and they at Progressive said that the current was not reliable enough from the generators, and they would not warrantee them if they were connected to those inverter generators.. So I just plug my unit into the generator with out the PI unit.. I also use the chain and padlock when connected to the park pole.
09-11-2015, 05:15 PM
#32
Left Coast
Did it simply for a test to see amp draw for less than a minute....I always use both if A/C is hard she'd do
09-12-2015, 07:22 AM
#33
Originally Posted by bob caldwell
What I just posted
Not what you just posted. Site gives in depth explanation and photos.
09-12-2015, 10:10 AM
#34
Originally Posted by cub22908
I have a permanent installed progressive surge protector (30 amp) and just bought a Generac 2000 portable generator from Costco. After going online and finding the fix for Error code 2 (No ground) the Progressive now will not let the generator online for code 4 (low voltage). It reads 122v with no load but must be dropping below threshold when trailer powered. I have everything turned off so must be battery charger pulling it down. My question is does anyone have a 2000w portable generator successfully powering their trailer through a Progressive 30amp Surge protector? I'm trying to find out if it's just the Generac having issues. Thanks.
I run a Honda 4000 watt generator with a 30 amp portable progressive surge protector with no problems. My guess is it is the generator. I hate to say it but with generators you get what you pay for. Can you return it? Your only other option is to disconnect the surge protector but I wouldn't recommend doing that. It sounds like it is doing its job.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
09-15-2015, 03:49 PM
#35
I just got back from camping trip with the Generac. I used it to charge battery and got through the trip that way. That's not what I wanted so returned the generator and will try the Honda 3000 Handi next year. So going from $500 to $2300! Oh well, I tried. I think some people were telling me to do the ground neutral plug, I had done that, no help. The Generac just couldn't react quick enough to initial load even with everything off, I even tried with battery disconnect off. Thanks for all the help. Dan
