Old 09-11-2015, 01:14 PM   #21
Left Coast
Originally Posted by SuicideSaints View Post
It could be the Genny is not up to the task or you need a "Ground-Neutral BondĒ jumper plug (edison plug).
Falling on def ears...
Old 09-11-2015, 01:16 PM   #22
My Honda 2000 runs with the EMS 30 hardwired just fine. Voltage is always between 116-124 depending on load. If I want to run the 15K A/C, I parallel two Honda 2000s together with good results. As you mentioned, I had to make a ground to neutral connector for the Honda in order for the EMS to play well with the Hondas.
Alternatively, you can switch off the EMS power management and just make it a surge protector via the remote switch (not recommended). This supplies power to your converter without the need for a ground/neutral adapter on the genny.
I suspect that your genny is dropping voltage on load and the EMS is doing its job.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 09-11-2015, 01:19 PM   #23
Left Coast
Originally Posted by aceinspp View Post
Honda does not recommend running an AC with the 2000. Good way to ruin AC. Later RJD
How many amps do you think a 13,500 a/c draws? 12...
Old 09-11-2015, 01:36 PM   #24
Who Dares, Wins
doc73's Avatar
Think it's 12 to 14 on start up and 8 or so just running. I can do it in one honda 2000 with the hard start capacitor and nothing else on. Once I try the thing with the converter or fridge it overloads.
Not sure about the generac but the 2000 on the Honda is a surge wattage.
The ac will trip it if I kept the economy throttle on, maybe try running your stuff with the economy throttle off if you have it and see if it keeps the voltage.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 09-11-2015, 01:57 PM   #25
Left Coast
Just plugged one Honda in....not using eco. I have a 3 amp draw before starting gen...refer is on....Running, adding a/c, shows 16 amps....no problem running....when camping, I use both.
Old 09-11-2015, 02:34 PM   #26
MrNiceGuy's Avatar
I had a similar problem and called Progressive. Their customer service is outstanding! I believe your problem is the need for a neurtral ground bond on the inverter/generator. Without going into great detail it is a plug that allows you to use your inverter/generator with a Progressive EMS. Progressive will give you instructions.
2015 Crusader 315RST
2011 Silverado 2500HD
MrNiceGuy is offline   Reply With Quote
Old 09-11-2015, 03:04 PM   #27
Left Coast
Get a normal 15/20 120 3prong plug...looking at prong end of plug, add a 14or16 gauge wire from ground terminal to prong on left side....of course, do this on inside of plug. plug into gen...done.
Old 09-11-2015, 03:20 PM   #28
Gregg Willow's Avatar
This site will explain the N-G Bond plug and how to make it...
Generator Ground-Neutral Bonding | No~Shock~Zone
2016 Ford F-150 4x4 Supercab XLT EcoBoost
2012 Salem Cruise Lite 221RBXL, Andersen No Sway WDH, (2) Honda EU2000i's
Gregg Willow is offline   Reply With Quote
Old 09-11-2015, 04:30 PM   #29
Left Coast
What I just posted
Old 09-11-2015, 05:09 PM   #30
TURBS's Avatar
Dometic recommends at least a 3500 watt generator.
It's right in there owners manual
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
generator
