Old 01-20-2013, 02:14 PM   #11
jimh's Avatar
Originally Posted by sideout1961 View Post
Is regular household power 110 or120? I get confused when I see these discussions. When I plug my 30amp at home with the adapter am I plugging into 110 or 120?
110, 115, 120, 125 are used interchangeably they are all refer to the same.
jimh is offline   Reply With Quote
Old 01-20-2013, 02:22 PM   #12
Oklahoma Proud
MillerTime's Avatar
X2 kinda like 220 & 240
Old 01-20-2013, 02:48 PM   #13
jimh's Avatar
i started to add that abt 220 but didn't want it in the same post as 110.
at home, i simply hook up with a 20 power cord. can run most anything just one at a time on the heavy users. will probably run 50 when i finally put a permanent outlet out there.
even if i only required 30 amp, i would be tempted to run the 50 and adapt down. as stated above future use.
Old 01-20-2013, 02:57 PM   #14
Steve Jackson
sideout1961's Avatar
Thanks all for the reponses it really helps. What is the need for such a large plug and cable if it is just 110? Is it because of the 30amp power that goes through it or is the service at a campground different than at home. Sorry if the questions seem dumb but electrical service is confusing to me. My only experience is changing outlets and switches at home.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 01-20-2013, 03:01 PM   #15
Oklahoma Proud
MillerTime's Avatar
Yes it is because if the amount of amps that each type of plug can handle or is rated for.
Old 01-20-2013, 03:09 PM   #16
GASPEDDLER's Avatar
The 30 amp plug with allow you to provide the full 30 amps the rig requires to run most of your electrical devices at the same time. The 15 amp will limit you to half of the juice available with the 30 amp. This will further limit the number of electrical devices you can operate at the same time.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 01-20-2013, 03:49 PM   #17
Steve Jackson
Just one more question. I have an unused outlet in my shed next to where the camper is parked. The breaker in the house for this line is 20 amp. Can I switch this out for a single pole 30 amp breaker that is mentioned in the article or is this not the correct thing to do? The camper would be the only thing on this line.
Old 01-20-2013, 04:34 PM   #18
Grizzlygibbs's Avatar
Definitely NOT ok. You need to upgrade the wiring as what is in that receptacle is likely 14 gauge romex. Depending on the distance from the box, you should have 10 or 8 gauge to be able to handle the amps!
I am not an electrician but know enough to not get shocked
Grizzlygibbs is offline   Reply With Quote
Old 01-20-2013, 05:08 PM   #19
Steve Jackson
Thanks for the advice. That's why I asked the question don't need any fire hazards!!
Old 01-20-2013, 05:19 PM   #20
Indeed!
