Old 01-20-2013, 05:23 PM   #21
caper's Avatar
Plus the outlet you are using can not be GFI. The reason being is that the TT has a GFI outlet and two GFI in line will not work.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-20-2013, 05:30 PM   #22
RV Newbie
buzzards27's Avatar
Originally Posted by sideout1961 View Post
Just one more question. I have an unused outlet in my shed next to where the camper is parked. The breaker in the house for this line is 20 amp. Can I switch this out for a single pole 30 amp breaker that is mentioned in the article or is this not the correct thing to do? The camper would be the only thing on this line.
Leave the breaker as is unless you resize the line out.
There is a rule of thumb about distance from the box, amperage and the size of the wire. The longer you run the heavier the gage should be. IF that is a 20 amp breaker the wire SHOULD be a 12 gage. But that 12 gage wouldn't be large enuf for a full 30 amp draw.
If you are only using the outlet to "store" the unit, not for AC or multi electric heaters, the existing outlet with a plug adapter would suffice. One 15 amp heater running full out, a few lights and a TV will really warm up a 12 gage wire... been there.
I ran two different 30 amp lines about 40' from the box so I can park in "long term" or " short term" parking, if I recall, 10 gage was enuf for either distance I had.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 01-20-2013, 05:52 PM   #23
Steve Jackson
sideout1961's Avatar
Yea my distance is a ways. It's about 90 feet. I'll take the advise just plug in with adapter. It's mostly just for storage during winter.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 01-20-2013, 05:56 PM   #24
Herk7769's Avatar
Everyone is right on the money.
Do not change the 20 amp breaker without replacing/upgrading the wires.
However what you can do is get a 30 amp RV socket to put on the end near the camper. The wiring connections on the socket PDF I sent will still work.
Just be aware that you will not have 30 amps available and you will need to monitor your power usage at the camper. Trying to pull more than 20 amps will trip the breaker in the main panel.
The advantage of using the RV outlet means you won't need an adapter for your camper's cable (every connection is a point of failure) and there won't be as much strain on the cable wires when using an adapter.
http://www.homedepot.com/p/t/2023071...368321&cj=true
HAM CALLSIGN - KC3FFW
Old 01-20-2013, 06:01 PM   #25
Steve Jackson
Thanks Lou I will look for that outlet at my local HD.
Old 01-28-2013, 03:31 AM   #26
You can use the adapter to plug it in at home, but not if you plan to run the AC. That requires more amp usage and could damage the AC unit. For using it, you should have a 30 amp outlet wired in.
MzZorro is offline   Reply With Quote
Old 01-28-2013, 06:41 AM   #27
Herk7769's Avatar
Obviously, 30 amps to the camper is optimal. However, my garage sub panel did not have enough oomph to supply 30 to the camper at the same time the house AC (wired from there) was running.
Wired the outside camper outlet with number 10 wire with an RV outlet; but fused it at 20 amps to protect the sub panel. I have NEVER tripped the 20 amp breaker even when running the Air Conditioner. I just never run any big draws at the same time. Heater or AC (OK) but no microwave, etc at the same time.
Old 01-28-2013, 07:54 AM   #28
TURBS's Avatar
As it worked out at our homestead where we park the camper its to far from any one building and I'm fortunate to have a lineman as a friend .
He brought out his bucket truck and dropped three 6awg wires from our power pole next to the camper were we installed two 30 amp fused disconnects with rv plugs.
I'll post up pics of my install in the spring.
Turbs
Old 01-28-2013, 08:02 AM   #29
Herk7769's Avatar
Turbs
So... not metered?
You are "Da Man".
Stay tuned as he may be visiting after this post!
Old 01-28-2013, 08:12 AM   #30
TURBS's Avatar
So... not metered?
You are "Da Man".
Lol BACK UP THE NON-METERED electrical theft!
This pole is after said metering device ....
Atleast near as I can tell it is.....
Lets see.... that big wire coming in goes over there and the 6 tag wires head to that pole after it runs to house and those three buildings then comes over to this
Pole .....
Yeah it runs through the meter. Right?
Yeah almost certain.
Turbs
