Old 01-19-2013, 08:34 AM   #1
Proper electrical hook up a home?
A Newbee here with trailer at the house for the first time. What is the right way to hook up electric to house current? Do I have to install a special outlet, is an adapter available at Camping world? Are there switches that have to be thrown? Thanks to anyone who replies. I have a 2011 Forest River Surveyor SP240.
happycampers2 is offline   Reply With Quote
Old 01-19-2013, 08:44 AM   #2
Dave_Monica's Avatar
Welcome to the forum!
All you would need is a 30A to 15A adapter. They sell them everywhere...probably in the RV section of Walmart.
Some have a dedicated 30A outlet to plug into allowing anything in the camper to be powered up. Ensure that it's a 30A 120V outlet not 220V...that mistake has been reported on here many times including work done by hired electricians.
Dave
Old 01-19-2013, 08:48 AM   #3
RV Newbie
buzzards27's Avatar
Do not install anything until you have researched the process. Connecting it wrong will damage your wiring. While the plug look a bit like a dryer plug they're different, ask for a RV plug.
This article should get you started. http://www.marxrv.com/12volt/12volt.htm
Sorry, here is the correct site... http://www.myrv.us/electric/index.htm
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 01-19-2013, 09:06 AM   #4
Triguy's Avatar
My replies in blue
Originally Posted by happycampers2 View Post
A Newbee here with trailer at the house for the first time. What is the right way to hook up electric to house current? What do you have at your house today? Certainly, you have a 15amp or maybe a 20amp circuit, but probably not a 30amp 120volt service. You will need adapters to go from your 30amp TT to the 15 or 20amp receptacle.
Do I have to install a special outlet Take a read through this thread. This is a forum discussion I had before I installed a 30amp service at my house.
Should I install 50 amp or 30 amp service?
is an adapter available at Camping world? Yes, and its always a good idea to carry it with you so you can adapt your 30amp trailer to work with 15amp at the CG if needed.
Are there switches that have to be thrown? No
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 01-19-2013, 09:24 AM   #5
GASPEDDLER's Avatar
If your rig is 30amp and you do not have a 30 amp RV outlet at home, you can use one of these. You can buy them at Walmart for $10. It will allow you to run some but not all your electrical in your TT. The best way is to have a dedicated 30 amp 120 v RV outlet installed-not 220v. Make sure to hire an electrician who knows RV electrical to avoid frying your converter and appliances- or worse.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 01-19-2013, 10:06 AM   #6
Herk7769's Avatar
Here is an excellent article on how to do it. If you do hire an electrician make sure he is given a copy before work starts.
HAM CALLSIGN - KC3FFW
Old 01-19-2013, 10:35 AM   #7
LaydBack's Avatar
I'm an electrician, and I'd encourage you to install the 30A RV outlet. They make one that comes in a weatherproof box. They also make other ones that also have other receptacles in them, depending on what might suit your needs. The reason I suggest the 30A is that people that have them at home tend to hang out in them, and need AC or whatever, so may as well have the proper setup. If you can give me more specifics, I can probably walk/talk you thru it.
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 01-19-2013, 02:58 PM   #8
Oklahoma Proud
MillerTime's Avatar
X2.-but I would do the 50 amp so you can upgrade your trailer without having to do the electric again.
Old 01-20-2013, 10:31 AM   #9
Steve Jackson
sideout1961's Avatar
Is regular household power 110 or120? I get confused when I see these discussions. When I plug my 30amp at home with the adapter am I plugging into 110 or 120?
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 01-20-2013, 02:01 PM   #10
Herk7769's Avatar
This should answer your question.
110 Volt Vs. 120 Volt | eHow.com
They are used interchangeably in the US.
