Old 09-14-2010, 09:59 AM   #1
Boyd's Avatar
Proper wiring for multiple batteries.
I run four 12 volt batteries in my coach, three are 180 AH and one 60AH..All sealed, deep cycle.
After reading this article: www.smartgauge.co.uk/batt_con.html
I think I better switch to other than straight-from-the-load, parallel wiring, to the diagram in method #2.
It appears as if my number one battery, the 60AH, is taking a real beating.
Any thoughts from the "Battery Gurus?"
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 09-14-2010, 04:12 PM   #2
You posted a good go to web. In your post you are running 180ah & 60ah batteries. Keep in mind it is best to match the bank, All 180AH or 60AH , Same Age & make. thank again for the article.
2010 wildcat 31ts
05 Ford F350 SD PS
camprat is offline   Reply With Quote
battery
