Old 06-10-2019, 11:28 AM   #1
Protecting generator from weather
For those that do not have a built in generator how do you protect yours from the weather?
I have a cover for storage but if I'm boondocking mine should not be in weather and my parallel kit is not weather proof.
I am going to run 2 generators; champion 2000 watt inverter, not the stackable.
Thanks!
banefamily is offline   Reply With Quote
Old 06-10-2019, 11:36 AM   #2
NMWildcat's Avatar
I place mine on a small pallet, to keep them off the ground. Then screwed uprights to all four corners. Then staked a tarp over the whole thing, leaving open spaces for ventilation and exhaust.
Have run this way for 13 years in every kind of weather imaginable.
Can't find a picture with the tarp, but here's the rest of my setup. Cheap, easy, compact. And yes, I are a redneckClick image for larger version
Scott and Liz - Southern NM
Old 06-10-2019, 11:40 AM   #3
Fulltime family RVer
Scott, freaking brilliant in its simplicity!
I considered the Gen Tent but they were too spendy for my blood.
Since I had mine mounted on the rear bumper when in use, I always considered a PVC contraption w/ tarps mounted to the wall of the rear of the camper and then going out over the generators. Never implemented it, though.
ependydad is online now   Reply With Quote
Old 06-10-2019, 12:14 PM   #4
I agree! Simpletastic!
I too believe the commercial covers are way too much money.
Here are some examples I've copied from.
Umbrellas can be had for $2 at Goodwill.
Coroplast is cheap too but doesn't fold to as small as an umbrella.
I haven't tried the Rubbermaid Tub but when I do, I will put cleverly placed holes in all the sides.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 06-10-2019, 12:20 PM   #5
NMWildcat's Avatar
Thanks! I also looked at all the store bought protectors and just never thought they were worth it.
I do like your idea with the PVC for yours on the bumper. I might have to explore that for a frame around my pallet!
That pic of mine is about three years old, since then I took a sander and rounded off the top corners of the 1x4 uprights. It was one of those 'a duh' moments when Liz asked me why didn't I do that so it would stop ripping the tarps. ;0 I just use those free 5'x7' tarps you get at Harbor Freight, but I went through them pretty regular.
What would we do without our smarter halves?
Old 06-10-2019, 12:48 PM   #6
CincyGus's Avatar
I generally put mine under the camper if it's raining with the exhaust pointing downwind. Generally there is some wind when it's storming. When it's not raining, just over close to the utilities side of the camper.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 06-10-2019, 01:18 PM   #7
jkoenig24
I used the Honda Handi 3Kw inverter generator for four years. It was chained to the A-frame on my travel trailer and, was exposed to weather (including rainstorms). It was VERY reliable, even when used in the rain.
jkoenig24 is offline   Reply With Quote
Old 06-10-2019, 01:24 PM   #8
I have an EU3000 a little to heavy for me to lift alone. I could probably do it but if I did pull something it would kind of ruin the trip! A tarp, string, a couple of long steaks I can wedge in my tailgate area. I put tennis balls on the long steaks so it doesn't poke a hole in the tarp. Lots of excess tarp on all sides and good clearance for air. I would love to have gen tent but I'm cheap.
Tom911 is offline   Reply With Quote
Old 06-10-2019, 01:31 PM   #9
rfifer
When we lose power in following a hurricane, my generator goes in the back yard under a 10' X 10' shelter. The legs of the shelter come in 3 pieces to achieve the full height, so I take at least one length of the 3-piece legs off to lower the canopy. It leaves enough room for good air circulation but is low enough that even blowing rain seldom touches the generator. That has always given good protection to our generator, even in squally weather. The same set-up can be done to many camp sites next to or behind the TT or MH.
rfifer is offline   Reply With Quote
Old 06-10-2019, 03:18 PM   #10
Thanks guys, after looking at these ideas and doing some brainstorming with dw I am going to put them under our folding table and throw a tarp over it then put the generators on the tarp.
generator
