Old 04-23-2016, 02:55 PM   #1
pup 7pin cord
i have a rockwood hw276 i got a new TV last month, last night i got the pup out of storage and hooked everything up. after about 3 right turns i lost my trailer lights. it seams that the cord that connects to my vehical is to short. about 3ft only and i need 4ft, does anyone know if i can order it or if i have to make one up? its 7 pin round and 6 pin recangle on the other. i was told its a rockwood thing only.
kinma13 is offline   Reply With Quote
Old 04-23-2016, 03:43 PM   #2
Ford Idaho's Avatar
I would be leaning to something like this.
Bargman 7-Way, RV-Style Connector w/ 8' Long Coiled Cable - Trailer End Bargman Wiring 54006-044
Use wire ties and or rubber bungee cord to hold the extra out of the way and off the ground, one could always cut off the unwanted length but it might come in handy some time.
Old 04-26-2016, 03:05 PM   #3
It might be easier to make up a new cable yourself. The 7 pin connector is available almost anywhere, including Wal-Mart. The 6 pin is going to be a little harder to find - you might have to go to an RV place with a good parts department (I think my 2000 Coleman Westlake also had a 6 pin connection at the trailer end).
So do what I did on the Coleman (I had the same issue) - cut off the existing cable near the 7 pin and re-use the 6 pin end. Splice in 7 new wires and the new 7 pin connector. Make it to any length you want. For the new wire, I would go up a gauge or two from what the factory used. Just make sure it will fit into the 7 pin Bargman.
I used butt-end weather-proof connectors - apply heat to seal the plastic after crimping and giving a real pull test to the joint. I then wrapped my new cable in electrical tape to protect against chafe and stiffen the cable. Nowadays, heat shrink is easier and faster (but you have to remember to slip the heat shrink on before making the connections).
Fred W
2014 Rockwood A122 A-frame
pgandw is online now   Reply With Quote
Old 04-26-2016, 03:29 PM   #4
Fred. I found a 64" cord with a 7 to a 6 connector at rv products online. We ll see if it works if not I'm going to make one like you said. Just wanted the least amount of work.
