Originally Posted by 10Ranger
Does anybody have an opinion of the quality of Continental batteries? Our 5er came equipped with two 12 volt RV/marine Continentals and was wondering if I should replace them. I have used only Interstate in the past and have no experience with the Continentals. We purchased our RV a little over a year ago and I checked the batteries under load this morning at 13.3 volts.
From what I can find on Continental Battery they are now just a distributor that more likely than not just re-brand batteries made by Johonson Controls, East Penn, Exide, or one of the super large manufacturers left in the industry.
They're probably as good as any other Marine/RV "Deep Cycle" battery. I'd use them as long as they last, making sure to recharge when 50% discharged, keep electrolyte levels up, and in the meanwhile set aside a few bucks a month so you can upgrade to your choice of two 6 volt True Deep Cycle batteries or maybe even a couple of the new Lithium batteries.
FWIW, I've always used a pair of 12V Deep Cycle batteries (usually something made by Johnson Controls) and by keeping on top of the amount I discharge them before re-charging, regular terminal cleaning and electolyte checks, I get no less than 3 years on them and some have lasted over 6.
Climate can also affect the life of these batteries. Hot climate, less life. Cool/Moderate climate, better life.
I wouldn't replace them until you find that they are losing capacity. A good battery monitor will help you wring a lot of life out of the batteries by giving you a clear indication of when it's time to recharge.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
