Old 09-20-2016, 02:16 PM   #11
Oh goody, a war about posts vs. private messages.
DrLewie is offline   Reply With Quote
Old 09-20-2016, 02:19 PM   #12
Wobbles's Avatar
If you log in to FRF Advanced, you can see the conversation.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 09-20-2016, 08:48 PM   #13
Or if your circuit tester or surge guard is plugged into some socket and is telling you that you have reverse polarity, take out the socket and hook the black wire to the copper colored side and the white wire to the silver colored side.
dsiegler is offline   Reply With Quote
Old 09-20-2016, 08:57 PM   #14
If Members must "Sneek Around" to have Q and A I think they should Also "Wear Masks"! Just ask the Damn Question! Youroo!!
Old 09-20-2016, 09:16 PM   #15
CaptnJohn's Avatar
X 200
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 09-20-2016, 09:18 PM   #16
Left Coast
Just don't want to sound 'uneducated'.......in subject
Old 09-20-2016, 09:26 PM   #17
What is your question? This forum is for helping which we can't do if you don't ask
Danesville is offline   Reply With Quote
Old 09-20-2016, 09:37 PM   #18
wmtire's Avatar
OK Guys, the member is most likely a little hesitant to ask an open forum question due to the fact he got some less than helpful responses in another thread he had previously.....as well as members sniping amongst themselves on that topic.
Several of the replies here are not really showing him this thread would be different.
If the OP doesn't want to post his question for all the members to see, then it won't most likely get a lot of helpful responses....but that is the OP's choice.
2011 Flagstaff 831 RLBSS
I went to my first meeting of Hypochondriacs Anonymous last night. I came out with more diseases than I went in with.
Old 09-21-2016, 08:40 PM   #19
danielabram71's Avatar
Ok I have had a bunch of pms. So here is what happened. I went camping at a state park near my house we camp there a lot. When I hooked up my power the surge protector showed rev polarity. I called maintenance and when he got there he seen the surge protector and said right off that when people use these he gets calls all the time. He said that even the local power company has came out and checked out the wiring and everything is ok. He used a meter and checked the line into the box we was hooked to. It all was good. He said that AEP practice is to hook the common and ground together. And he said the power company said that is why it shows rev polarity. Everything in the camper worked ok. Didn't have problems out of anything. So my question is. Is it possible that the ground and common could be the problem? And if there was a problem would I have have problems with my ac or something else? Just trying to find out what may have been wrong. And yes I have had rev polarity at the park before. But it was packed. So this time was not as many there so I wanted to see what maybe wrong
2014 1500 GMC
2015 solaire 267bhsk
danielabram71 is offline   Reply With Quote
Old 09-21-2016, 08:41 PM   #20
Oh I forgot my camper is a 30amp
2014 1500 GMC
