Old 01-25-2016, 03:00 PM   #11
Witch Doctor's Avatar
That is pretty good every 3 or 4 days not to draw down past 50%. Also didn't you live in Napa Calif. ? Now in Washington? Also is Mod ass't new, congrates and good luck
Coachmen M/H
Concord
2018 / 300 DSC
Old 01-25-2016, 07:15 PM   #12
It will charge quicker with both working.
NorSnrub is offline   Reply With Quote
Old 01-25-2016, 08:46 PM   #13
bikendan's Avatar
We retired in 2014 and moved to Washington, where all the DW's family lives. We've owned 5 acres and house for 8 years, knowing we'd eventually move.
As for as the Mod Asst., I've been a mod for quite awhile, I just label myself(tongue in cheek)as an "Assistant", since I'm not as good at it as the others are.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-25-2016, 09:33 PM   #14
Too Tall's Avatar
I did some testing this afternoon,
My 2104 Rockwood with the battery disconnect open draws 50 ma. I really think the disconnect switch is wired wrong. (I had to rewire the AC thermostat because the low fan didn't work) I notice that the radio system, USB port stays on. What's significant is the current draw is 1/3 amps with the switch on and nothing running. Add the frig and it's 1.6 amps. Lights are about a 1/2 amp each.
My battery was pulled down from fully charged to 12.4 volts. (That's about a 30% discharged or 70% charged) When I plugged in shore power it charged at 1.3 amps. Kind of slow.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 01-25-2016, 10:30 PM   #15
TURBS's Avatar
Co detector is or may be hardwired to battery bypassing the cut off switch
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-25-2016, 11:56 PM   #16
Originally Posted by bikendan View Post
Depends on how far they are down and if I've used the furnace.
Generally 2-3 hours every 3-4 days, IF I'm not using the furnace.
How do you know with your converter that your batteries are fully charged? I don't see any charge status indicators on WFCO converters.
Skyliner is offline   Reply With Quote
Old 01-26-2016, 12:15 AM   #17
Bluepill's Avatar
I have a problem with the factory radio. If I disconnect the battery and then reconnect it, the radio turns on by itself. Rather than installing a disconnect switch for the radio, I just detach the removable faceplate whenever I am not using the radio (which is almost all of the time).
2008 Itasca Meridian 37H
Old 01-26-2016, 12:19 AM   #18
Bluepill's Avatar
On the subject of leaving the battery connected when using an external charger: Some chargers will supply over 15 volts, which may be too much for some connected loads. Monitor with a voltmeter a few times to see how high your charger voltage goes to be safe.
Old 01-26-2016, 06:01 AM   #19
I installed a meter that gives me a voltage read out got it from Amazon and it fits behind the window of the panel. At least it shows what the convertor is suppling. That's my battery voltage after 24 hrs of the convertor off but it will also show you 13.6 13.1 and 14.6 when the convertor is on. Cheap way to see, cost about 5 bucks.
Name:	battery voltage read out 003.jpg
Coachmen M/H
Concord
2018 / 300 DSC
Old 01-26-2016, 10:35 AM   #20
TGR
TGR's Avatar
I plan to charge my TT battery with an external battery charger. If the battery disconnect is off, can i charge the battery via a 12 amp charger powered by a portable generator without disconnect the battery from the TT?
I'd like to have the generator running and connected to the 30 amp supplying power to the trailer and at the same time having a 15 amp battery charger, charging the batteries.
I know there's a debat as to whether the converter charger will charge batteries as quickly as a car battery charger like a Schmacher or equivalent. From my testing, it looks like using the onboard charger is not adequate. But I don't want to rehash that, just would like your opinion on charging the battery while connected to the TT. I don't see a problem but I don't see a lot of things. Seems it would be equivalent to charging a car battery without disconnecting it from the car? Sorry for being so long winded. You guys have been very helpful.
I doubt if your scheme to disconnect the battery and charge it with an external small battery charger will cause any harm but I can't envision a normal situation where your converter wouldn't charge your batteries faster than the external 12 to 15-amp battery charger and do it without the hassle of messing with a battery charger.
Standard WFCO converters supply between 45 and 100 amps of power, depending on the model, to charge your battery and run any 12-volt needs of your RV.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
battery, charging
