Old 01-28-2013, 10:59 PM   #31
Herk7769's Avatar
Originally Posted by MillerTime View Post
If you put in a 50 amp plug- it's pretty much idiot proof in my opinion. Its the 30 amp 3 prong plugs that most don't understand- since old style 3prongs, like herks dryer were 220, most just assume its a common/ground and 2 positives
Too true. But without a neutral a 50 amp socket is heartbreak waiting to happen.
HAM CALLSIGN - KC3FFW
Old 01-28-2013, 11:05 PM   #32
Oklahoma Proud
MillerTime's Avatar
True, I guess sometimes the impossibe is possible- the news is full of it.
Old 01-28-2013, 11:09 PM   #33
Herk7769's Avatar
Originally Posted by RoadTrip View Post
So now I"m confused - if the dogbone adapter will take care of everything - then do I still care about the neutral?
The dogbone only uses one hot and the neutral (and the copper ground of course). If the neutral is not there; there will be no power to a 30 amp camper since there will be no return path for the 110 volts.
Old 01-29-2013, 11:52 AM   #34
Graduate Member
RoadTrip's Avatar
Thumbs up
AWESOME!
Thanks so much!!!
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 01-29-2013, 03:14 PM   #35
Why can't you use 3 wires? Two wires are hot and the other is used as a neutral and you put a jumper to the ground. If you look inside your panel box both the neutral and the ground bars are basiclly connected to one common ground wire that comes in the main service enterance and also connects to a ground rod driven into the ground outside. The older style dryers and stoves used this system with 220v. and they had part of their systems running off 110-timers and clocks and motors were all 110v not 220. By using three wires as discribed above you have 220v across the two hot wires but you also have two 110v circuts if you go from each hot wire to the neutral.
ayotte is offline   Reply With Quote
Old 01-29-2013, 03:26 PM   #36
It's called National Electric Code.
Old 01-29-2013, 08:36 PM   #37
Graduate Member
RoadTrip's Avatar
Here's pics - I noted that someone said a 50amp outlet has 4 prongs for the RV outlet. So.....does that mean this is wrong?
Name:	Cs iphone 017.jpg
ID:	23641   Click image for larger version
Name:	Cs iphone 013.jpg
2013 - 53 days
2012 - 26 days
Old 01-29-2013, 08:49 PM   #38
Jack of All Trades
RJHuser's Avatar
That is not a 50 amp 4-wire receptical nor a 30 amp RV receptical. It looks like an older three wire 220 VAC receptical, which would have 220 VAC between the two vertical slots and a ground wire.
What ever you do DO NOT PLUG YOUR RV INTO THIS RECEPTACLE!!!!!
Great damage will be done, costing you thousands of dollars.
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 01-29-2013, 08:52 PM   #39
That is a 220 V outlet for a dryer. That is not a 50A RV outlet. If you look at millertimes post he shows a 50A TO 30A adapter you need a plug that the 50A side would fit into.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 01-29-2013, 08:54 PM   #40
Graduate Member
RoadTrip's Avatar
ROFLMAO - seriously???
Time to call another electrician....
2013 - 53 days
2012 - 26 days
