Old 01-29-2013, 08:02 PM   #41
Herk7769's Avatar
Originally Posted by RoadTrip View Post
Here's pics - I noted that someone said a 50amp outlet has 4 prongs for the RV outlet. So.....does that mean this is wrong?
AARRRRRGGGGG danger
THIS is why I HATE giving advice over the internet. Until you posted those pictures I had no idea what a moron you had for an electrician.
What ever you paid him, you were robbed.
HAM CALLSIGN - KC3FFW
Old 01-29-2013, 08:07 PM   #42
Herk7769's Avatar
RV Electric
THIS is what you paid for. What you GOT was screwed.
Old 01-29-2013, 08:21 PM   #43
Jack of All Trades
RJHuser's Avatar
Actually, there is no such thing as a 50 amp RV plug/receptacle.
The 50 amp service on a RV uses a standard 4-wire plug/receptacle -a NEMA 14-50.
By the way, what your electrician installed is a NEMA 5-50 receptacle, which is a 2 pole 3-wire grounded 125 VAC receptacle. So, if he wired it with two hots and a ground (220 VAC), deferent lay find a different electrician!!! This guy is a danger to everyone - you, himself, the guy that follows up on his work, the electric company, etc.
DO NOT USE!!!!!
Rick & Debbie; Brandy & Schnoodle (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 01-29-2013, 08:37 PM   #44
Jack of All Trades
RJHuser's Avatar
Check these two sites for good explanation of NEMA plugs and receptacles and their uses
NEMA connector - Wikipedia, the free encyclopedia
NEMA Plug & Receptacle Configurations Reference Chart (Straight Blade)
Old 01-29-2013, 09:05 PM   #45
fast murray's Avatar
I don't think you could plug into that with anything unless you made your own adaptor. That is a straight 250 volt welder plug. It likely doesn't have a separate neutral to it as for that receptacle would be wired with an 8-2wg cable. You could use the wiring that is already installed to make that into a 30 amp 125 volt recep. It would be heavier wire than necessary but that's alright. Looks like he did a nice job installing it though!
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 01-29-2013, 09:36 PM   #46
wmtire's Avatar
DO NOT USE!!!!!
I think it is actually a NEMA 6-50R receptacle, which is 250 volt.
The NEMA 5-50R has the large blade on the right hand side while the 6-50R has the large blade on the left.
I also am wondering the direction the pic was taken, as it appears the receptacle could be upside down.
Give a cookie to fast murray, you'd think he was an electrician by trade.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 01-29-2013, 09:57 PM   #47
Oklahoma Proud
MillerTime's Avatar
Roadtrip I thought your outlet looked familiar- just went out and looked and yep, all of the 220v welders we have and have used for as long as I can remember use thid type.
- here's the pic of our welder outlet and plug- matches yours
Old 01-29-2013, 10:21 PM   #48
Jack of All Trades
RJHuser's Avatar
WMTIRE
You're right, NEMA 6-50.
I original had that, looked at the picture again and changed my post - I didn't notice it was upside down -DUH!
Even with that, I would find a new electrician.
Old 01-29-2013, 10:22 PM   #49
Herk7769's Avatar
I am staying out of this.
I am of the opinion that the whole thing needs to be done right either as a 30 amp outlet (requires less rework) or ripped out entirely and the correct wiring for a 50 amp service put in.
My 2 cents and done.
Old 01-29-2013, 10:58 PM   #50
It all makes my hair hurt...... I'm Bald !!!!!
grayfox is online now   Reply With Quote
