Old 09-24-2014, 10:47 AM   #11
RKR
RKR's Avatar
I've pretty much checked all mentioned. I'll dig into it deeper when I get back.
Rho, good to know it can be done.
Thanks guys
Sent from my high tech gadget
RKR is offline   Reply With Quote
Old 09-28-2014, 04:31 PM   #12
RKR
RKR's Avatar
Made it through the trip. Funny thing is that when I disconnected the battery cables and hook up the battery tester to the cables it showed 12 volts. When I put a load on it it showed weak. This is the power coming from the converter only. I understand it's a slow charge system so I think the weak reading really doesn't have any bearing right ?
So, it appears the converter is working but it just can't keep up. The idiot gauge for the battery in the 5r drops all the way to the lowest reading. When I pulled the battery out the charger showed only 10% charged.
The converter is the original and is only 2 years old.
Old 09-28-2014, 06:17 PM   #13
Kaadk's Avatar
Converter should be reading high 13 to almost 14 if it was working right. So, it sounds like a bad converter.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
Old 09-28-2014, 07:12 PM   #14
RKR
RKR's Avatar
Quick Question
That's what I thought. Gonna swap it out but not with the same brand. I just installed my Progressive 50 amp EMS for the second time. I've had enough time in the basement. When I go back in to install the new converter it will be a good one.
