Old 12-08-2019, 04:25 PM   #1
Ed and Joy's Avatar
Rear running/brake/signal lights lost their ground
Hello:
2013 Columbus rs320
I lost my rear running lights. I recovered by providing a ground,to the frame, at the liscence plate lamp and all us good but i want a more permanent fix. Does anyone know where the ground should be for these rear lights?
Ed and Joy is offline   Reply With Quote
Old 12-08-2019, 04:51 PM   #2
Retired Old Fart
dward51's Avatar
Its probably at the frame. Follow your negative lead from the battery and I bet it bolts to the frame. The light probably picked up their feed from the frame at the rear of the trailer somewhere.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 12-08-2019, 10:06 PM   #3
Yes, negative lead from battery bolts to frame and usually with just a small self tapping screw that rusts worse than a crescent wrench in a salt water tackle box.
Losing lights is one sign that it's time to "repair" the ground connections. The one from the battery, the one from the Power Distribution Panel/Converter, and any other ground connection to the frame should be cleaned and secured properly.
Might even find that batteries charge quicker too.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
brakes, light
