Old 10-16-2015, 03:59 PM   #11
The HF 45W kit I've looked at is a big unit (3 panels), heavy and bulky for what you get. A better choice from HF is the 24V briefcase unit that's light weight and portable. The two panels are inside the case and are fully protected when the case is closed.
Phil
pmsherman is online now   Reply With Quote
Old 10-17-2015, 10:19 AM   #12
Thanks for the comments. I already have the battery secured to the trailer with a chain and padlock. I actually got the idea of a maintainer from several seeing several panels on the ground elsewhere in the lot. I'm not too worried about security.
I'm currently taking the battery home for charging but, at my age, that's getting harder and harder. I also haven't found a good place to keep it home in range of a wall outlet.
I'm not looking for a large system like HF one. I just want to do a good job of maintaining. The other panels I see in the lot appear to be 5W because of their size. I don't know if either uses a regulator.
Jerry
2007 Surveyor SV 230
2013 F150 Ecoboost
azjerry is offline   Reply With Quote
Old 10-17-2015, 06:49 PM   #13
Blackhat6mike's Avatar
Originally Posted by Tom48 View Post
Go tiny for just a maintainer or get real solar. HF 45 watt solar is basically cheap junk. A complete 60 or 100 watt mount it on the roof. WindyNation.com. or for slightly more Renogy.com. same stuff, slightly more cost but I do like their roof mount brackets, although my WindyNation.com stuff sits up there just fine. 100 watt complete under $200 delivered ups when we got ours
X2 The Renogy system is a good value, good customer service and YES, you do need a controller. Mount your panel on the roof and forget about the musical chairs with the battery. Once and done.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 10-20-2015, 10:14 PM   #14
KAS
I got a flexible solar panel at West Marine 18 years ago, and it still works! I use it to maintain my RV battery and, when camping, my boat battery. I am told that for panels under 10W you don't need a controller. I found the same one on West Marine's website.
Boat Parts, Sailing, Kayaks, Paddleboards and Marine Electronics | West Marine
and search for
RDK PRODUCTS 3W Semi-Flexible Monocrystalline Solar Panel.
KAS is offline   Reply With Quote
Old 10-21-2015, 04:34 PM   #15
I went ahead and ordered this from Amazon:
Amazon.com: Battery Tender 021-1163 5W Solar Maintainer: Automotive
It's got a regulator whether I need it or not. So far it seems to working just fine.
Jerry
2013 F150 Ecoboost
Old 11-16-2015, 01:23 AM   #16
You should be fine. I've used a 5 watt panel to maintain a dual purpose wet cell RV battery on my boat for 10 years. First battery lasted 8 years. Didn't have a regulator on mine, but also had no parasitic losses. I even measured it providing some charge with more than 3 inches of snow on it when it was new. That was hard to believe but measure with a meter.
Calgary, AB Canada
Ridenfun is offline   Reply With Quote
battery, solar
