Old 02-07-2016, 10:01 PM   #1
Red=Positive ???
I took the battery out for the winter and now that I'm ready to install it, not sure which wire is the positive. I have a red wire and a white going to the battery box I would think that the red would be positive?? am I right
1oleman is offline   Reply With Quote
Old 02-07-2016, 10:04 PM   #2
Red should be positive.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 02-07-2016, 10:05 PM   #3
What color is your RV because we dont know what kind or model it is? Youroo!!
Old 02-07-2016, 10:23 PM   #4
Evereddie's Avatar
Yes, red is positive. If you have a multi-meter you can verify this. Measure on the ohms scale between the white wire and some part of the chassis of the trailer. (find some bare metal or a screw, bolt, or nut) It should measure 0 ohms or a dead short.
Evereddie is online now   Reply With Quote
Old 02-07-2016, 10:34 PM   #5
trbomax's Avatar
White is almost always neg.black or red is positive.Unfortuneatly there is no "code" for low voltage wireing,but what I stated above will cover 95% of any factory instalations.
trbomax is offline   Reply With Quote
Old 02-07-2016, 10:41 PM   #6
Just make sure you are on the lowest ohms scale, especially if you are using an analog meter. On the higher ranges, your meter may measure full swing through internal circuits such as a light bulb. Also make certain the shorepower is unplugged first. Ohm meters don't like voltage/current.
Another test is to insulate the red and white cable ends, then plug the unit in and check polarity from your converter, but I would de power any other 12 volt appliances, like radios. Our 12 v batteries make better regulators than some converters.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 02-08-2016, 08:33 PM   #7
Thank you all good replies, I figured it was positive but was use to seeing black also.
youroo he TT is a Surveyor 220RBS
Old 02-08-2016, 10:47 PM   #8
It looks as though it is white and brown.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 02-08-2016, 11:06 PM   #9
schrederman's Avatar
Red is negative in the telecommunications world... and it's -48VDC. Everywhere else, red's positive... that I know of anyway.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 02-09-2016, 08:21 AM   #10
Could there be a small wrap of black electrical tape on the white wire close to the lug that you overlooked?
phillyg is offline   Reply With Quote
