Old 05-12-2014, 07:32 PM   #1
Rupkin2's Avatar
replace blown 1076 bulbs
I have a Crusader 320 RTL with 3 pendant lights over the sink/counter.
Well one of them has burnt out, no big deal, so I thought.
I have no idea what a person has to do to remove the bulb from the socket.
Thinking this 1076 bulb would be similar to a 1056 I pushed but wouldn't turn.
I have tried to just turn and the shade turns, hold the shade and turn, the socket turns.
I have even tried to just pull the bulb out, this really doesn't seem like a good idea.
I read somewhere here on the forum that one has to dismantle the whole light assmebly...........really? I'm pretty sure there are campers out there that have no clue on how to do this so I would think that idea is out.
Does anyone actually know how to remove the 1076 bulb from the socket without breaking the shade?
John
P.S I hear/read alot about the LEDS is it worth it?
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 05-12-2014, 08:21 PM   #2
Had the same problem with lights over the sink, disassembled the fixture, put on gloves and pushed-twisted until the bulb came out. Apparently it had corroded and was stuck in the socket. Installed new bulb, but first coated it and the socket with dielectric grease to prevent corrosion.
Sirsea is offline   Reply With Quote
Old 06-02-2014, 07:57 PM   #3
Rupkin2's Avatar
Well I finally removed the bulb from the socket.
Yep had to disassemble the fixture.
I removed the 2 screws holding the fixture in place, unscrewed the shade, pulled some wire out from the ceiling, pushed everything up and pulled the socket part out past the shade here I could actually see the darn thing.
Anyway I pushed and turned, pulled and nothing.
Pushed and turned one more time and poof, came out like it was suppose to..........hmphWhy didn't the bulb pop out like this in the first place?
Anyway there was no corrosion.
Now I have to find who sells these 1076 bulbs.
Maybe look into the LED's
John
Old 06-03-2014, 05:47 AM   #4
fonzie's Avatar
Your local Canadian Tire should have those bulbs.
Fonzie
Old 06-03-2014, 06:51 AM   #5
Ford Idaho's Avatar
Are the contacts in the socket spring loaded?
While you have it apart look for interference.
All you should need to do is push the bulb into the socket and twist.
Old 06-03-2014, 03:02 PM   #6
zs325RES's Avatar
Same issue here - very hard to push and turn them out, but it can be done.
I had these burn out quickly too and replaced them with these LEDs:
BA15D 1142 1076 High Power Car LED Bulb 30 5050SMD DC12V Warm White | eBay
Be sure you get the 30 x 5050 type which have the same lumen output as the incandecents.
Very happy with them so far.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 06-03-2014, 03:05 PM   #7
Ford Idaho's Avatar
Could you tell what was making it hard to push in?
Old 06-03-2014, 09:45 PM   #8
Rupkin2's Avatar
Thought Canadian Tire would have these but they didn't. Went to 3 different stores niether one had them.
Didn't see any interference, base of bulb was clean. Not sure why it was so hard but as I mentioned earlier the bulb suddenly came out easliy like it should.
Might try the other 2 for the halibut.
John
Old 06-04-2014, 06:37 AM   #9
Ford Idaho's Avatar
DiElectric Grease
Dab a very small amount on the base.
How to Keep Light Bulbs From Sticking in Sockets | eHow
