Old 03-16-2015, 04:14 PM   #1
Replace flood light bulb?
How do I replace the bulb in my flood lights?
I have a 2014 V-Lite with flood lights on both sides. The door-side bulb is burned out.
I can see a little hole in the bottom of the white plastic trim, but I don't see a way to get into the fixture to replace the bulb. Has anyone else had any luck with this?
Thanks!
2014 Flagstaff V-Lite 30WTBS
2016 GMC Sierra SLT 2500 Crew Cab 4x4 Duramax
2008 Surveyor SV-234 (SOLD, but not forgotten)
2008 Nissan Titan Pro-4x crew cab (SOLD, was a great truck)
smithmdsmith is offline   Reply With Quote
Old 03-16-2015, 04:25 PM   #2
Just squeeze either the top and bottom or the sides and the lens will pop off.
Old 03-16-2015, 04:40 PM   #3
S1LV3R4D0's Avatar
Yep, there are tabs on top and bottom. I just popped mine off and replaced them with LED's. No bug attraction ;-)
These right here work awesome!!
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Doug and Toni & Penny
2014 Wildcat Maxx T28RLS TT
2013 Silverado Z71 5.3L 3.42gears
Nites Camped 2015: 21
S1LV3R4D0 is offline   Reply With Quote
Old 03-16-2015, 04:43 PM   #4
Great! Thanks! Which LED bulb did you use?
Old 03-16-2015, 09:07 PM   #5
HONDAMAN174's Avatar
Yep- I went with the same bulb just in bright white. Nice and bright!
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 03-17-2015, 09:02 AM   #6
S1LV3R4D0's Avatar
I put the amazon link in my first post. Should take you right to the bulb.
Old 03-17-2015, 09:17 AM   #7
I had trouble squeezing mine with just my hands so I used a flat screwdriver and gently pryed it open on the top.
2013 Coachmen Freedom Express 291 QBS
2013 Chevy Silverado 1500 Crew 4x4 5.3
Jandj1026 is offline   Reply With Quote
Old 03-17-2015, 09:24 AM   #8
Thanks...sorry I missed it.
Do you know if the same bulb will fit in the yellow "porch" light?
Old 03-17-2015, 09:29 AM   #9
onetonford's Avatar
Yes it will just changed mine all out.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 03-17-2015, 09:36 AM   #10
S1LV3R4D0's Avatar
Most definitely. Its just a yellow lens. The porch light and door light are the exact same and both mine have LED's in them now. I changed out all the ones inside also but those are different bulbs then outside ;-)
light
