Old 04-27-2014, 09:12 PM   #1
ptt87's Avatar
Replacement Fuses
I'm trying to track down some spare fuses to keep on hand in case one blows, but can't seem to find the type that my manual calls for.
The manual says specifically to replace with the ATC Type 257 by Littelfuse, but all I can find are ATO fuses. Even the Littelfuse website carries only ATO.
Does anyone know where I can get this type? Does it matter - ATO vs ATC?
Thanks!
Pete & Laurel
Peachtree City, GA
2012 Surveyor SP280
2007 Ford F-150, 4.6L V-8
Equal-i-zer
ptt87 is offline   Reply With Quote
Old 04-27-2014, 09:48 PM   #2
VinceU's Avatar
Thanks!
Here ya go: source Wik
The ATC fuse has a fuse element that is closed or sealed inside the plastic housing and the ATO fuse has a fuse element that is open or exposed on the bottom of ...
VinceU is online now   Reply With Quote
Old 04-28-2014, 07:38 AM   #3
Ret E-9 Anchor-clanker
donanddona's Avatar
Amazon.com: Littelfuse ATO15BP ATO 257 Series Fast-Acting Automotive Blade Fuse - Pack of 5: Automotive
donanddona is offline   Reply With Quote
Old 04-28-2014, 07:48 AM   #4
VinceU's Avatar
ATO newer style, same function.
Old 04-28-2014, 08:44 AM   #5
f5moab's Avatar
From what I have been told is you can replace an ATO fuse with an ATC fuse, but you should not replace an ATC fuse with an ATO fuse. That is for truck (car) applications so not sure about something that is not subjected to outside elements such as in a trailer.
f5moab is offline   Reply With Quote
Old 04-28-2014, 08:53 AM   #6
Brother Les's Avatar
Thanks!
If the Littlelfuse website carries only ATO .... then I think they are fine to use.
ie. you can probably skimp a little on what the 'Manuel' says.....
Brother Les
fuse, replacement
