Old 06-25-2012, 12:16 PM   #11
Herk7769's Avatar
Originally Posted by RickV View Post
OK so it finally stopped raining for a while. I go out and install new assembly. I hook up the pigtail to the truck and I have this happening, turn signal works without headlights on, with the headlights on the turn signal bulb stays on like as if I was stepping on the brake. Any suggestions?
Bad ground?
Wrong wires connected to filements?
HAM CALLSIGN - KC3FFW
Old 08-01-2012, 01:35 PM   #12
I have been kinda busy and hadn't had a chance to address this problem until yesterday. I checked the voltages at the Truck all were good, plugged in pigtail in and now turn signal/brake light on left not working at all. I checked the voltages at the pigtail and all are 13+ volts except for the left turn/brake/running which is at 4.6 volts. I was using the battery pin and then read the voltage at every other pin. I am thinking of running new wires but, does anyone know if they are ran through the walls or are under the bib or whatever it is called? I have a 2006 Rockwood 8280SS.
RickV is offline   Reply With Quote
Old 08-01-2012, 01:58 PM   #13
Herk7769's Avatar
My sockets are corroded and the bulbs can't be removed.
I bought complete new tail lights. They are very cheap.
Old 08-01-2012, 02:05 PM   #14
Yeah I had the same problem and replaced the whole assemblies but still having same problem. Just trying to find out where the wiring harness runs.
Old 08-02-2012, 03:59 PM   #15
OK got a lot resolved today. Had the thing hooked up kinda wrong. FR uses a red wire for the left turn/brake signal. The replacement socket setup has green, black and white. I had hooked the green to green and PO had spliced a black wire to the red wire so I hooked up black to black. This was wrong the green wire on the socket is the turn signal and the black is the running light. So after changing those around the running light was normal. Still had a problem with the turn signal not working. I checked voltages at the truck connector and they where working properly so I used a jumper wire at the trailer plug and jumped from the battery post to the turn signal post and it lit like it was supposed to. So I assumed that the trailer plug was the culprit, it is probably the original one. I picked one up the this afternoon and will install it tomorrow morning when it is cooler out. Hopefully that should do the trick. BTW the wiring harness does run under the camper and not through the walls but, I didn't have to mess with it but at least now I know where it is.
led pad
