Old 07-19-2015, 03:13 PM   #1
replacement therostat
I have an old analog stat. This looks like a decent replacement but was wondering if anyone has tried it.
http://www.amazon.com/dp/B007S0DRBE/...I1OJTHAZFJCQSC
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 07-19-2015, 03:23 PM   #2
Just put one on my Mini-lite. If you have a two speed fan on your A/C, you'll either need to pick one speed or the other, OR install a small single pole single throw (spst) switch to allow you to switch speeds. I'm attaching pics of my install and a wiring diagram.
In the 2nd pic, you can see that there are 3 slots on the piece on the right (opposite the small spst switch). I had to cut these out to make a larger hole, as you can see in the 3rd pic. Ultimately, I had to enlarge this all the way down to the switch hole below it, but it's easy to do.
Another alternative to the spst switch in the thermostat is to install a spst rocker switch in the wall next to the thermostat. Here's an example of a rocker switch and wall plate that will work:
http://www.americanrvcompany.com/JR-...per-Trailer-RV
I'm considering it, as I think I overheated the spst switch when I soldered the wires on it, and it's a bit "touchy."
Name:	Digital T-stat 1.jpg
ID:	83360   Click image for larger version
ID:	83361   Click image for larger version
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 07-19-2015, 04:00 PM   #3
JR Products 12625 Black 12V Standard On or On Switch Camper Trailer RV
JR Products 12855 Black Single Face Plate Camper Trailer RV
Thanks for the quick reply. Had trouble with the heater but believe it a problem with the stat. Don't want to spend 60 bucks though to find out. This looks like a reasonable one for the trailer.
If I were you I would replace the switch but use crimp (automotive) fittings on the wire. Stay clear of solder on "cheap" switches unless you have a very low wattage iron. You can get everything at Radio Shack or a good auto parts store.
Jim
George Bernard Shaw
Old 07-19-2015, 06:08 PM   #4
I got the spst switch you see at Radio Shack. But it's very small and you have to solder the wires on. I was using a low wattage soldering iron, but sometimes you just mess it up.
We've only been out once since I installed it, so we'll see how it goes. If it's still squirrelly, I'm going with the rocker switch.
Old 07-19-2015, 06:31 PM   #5
The rocker is the better switch. A lot of what RS sells is junk but there are not a lot of places to buy that type of thing anymore.
About 30 years ago I met a big wig from RS. At the time I was rebuilding a few ham radios for a friend. I told him as far as I was concerned that RS sold a lot of junk ! A friend of mine went thru 4 multi-meters before we found him a good one. I will never forget what he told me!
"Jim, your right, BUT JUNK SELLS!"
Jim
George Bernard Shaw
Old 07-20-2015, 06:14 AM   #6
waiter21's Avatar
My thermostat runs just the furnace. I replaced the old mechanical (it was very hard to read) with a new digital one.
Install new Digital furnace thermostat | 2001 Coachmen Mirada 300QB
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 07-20-2015, 06:22 PM   #7
waiter21; What controls your AC?
Old 07-20-2015, 10:14 PM   #8
waiter21's Avatar
My AC unit has its control panel on the ceiling. My wall thermostat only controls me heater.
Old 09-08-2015, 10:22 PM   #9
D_B Travelers's Avatar
I just ordered this unit from Amazon: http://smile.amazon.com/gp/product/B...ilpage_o06_s00 as it was a direct replacement for the analog OEM Coleman thermostat. You can get it other places but check the numbers on the back of your analog thermostat and then check to see if the new digital is made as a replacement. Wires connected the same, 5 minutes and it works SOOOO much better! As my TT is still under warranty I didn't really want to kill the warranty by taking a chance on making a home thermostat work. But then again, that is just me. I figure for the money I have in this thing another $75 isn't going to sink me and I will know it will work.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 Ė 1996)
D_B Travelers is offline   Reply With Quote
Old 09-09-2015, 11:04 AM   #10
DaveSchwartz's Avatar
The Coleman-Mach (RVP) thermostat catalog is here and most models have a replacement compatibility list. I also found that if you look them up on the http://www.makariosrv.com/rv-thermostats/ site, the descriptions are a pretty good compatibility reference - they even have a guide.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
replacement
