Old 06-28-2012, 09:25 PM   #1
Replacing Tank Sensors
I have just replaced the sensors on my black tank with the Horst Miracle Sensors. Prior to the change the tank always showed full regardless of whether we had just dumped. Since the change the tank always shows empty. Ground is good and wires are back in the original position (on the new sensors). What went wrong?
6wheelgypsey is offline   Reply With Quote
Old 06-28-2012, 10:03 PM   #2
jimh's Avatar
i would recheck and make sure a couple wires weren't switched. maybe the top and common. if that is good, see if they are tight.
that is abt all i can suggest. i don't see how anything else could have happened.
jimh is offline   Reply With Quote
Old 06-29-2012, 08:44 AM   #3
Take all the wires loose, make sure they are not touching anything, and then take a reading. Should be empty. If not, the problem is in the board, not the sensors.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-29-2012, 09:19 AM   #4
Herk7769's Avatar
Is the problem with the black tank or all tanks?
If all tanks and you only worked on the black, the board is cooked.
If the black tank only.
PROBLEM:
DISPLAYS “F” ON ONE OR MORE TANKS, OTHERS TEST GOOD.
TEST:
(A) VERIFY THAT LEVELS IN TANKS DO NOT MATCH DISPLAY
(B) SWAP TANK CONNECTINS ON PANEL AS FOR PREVIOUS
PROBLEM. RESET TANKS TO SEE IF PROBLEM HAS ALSO
CHANGED TO ANOTHER TANK OR IS STILL IN THE SAME
TANK.
DIAGNOSIS:
(A) IF STEP (2) ABOVE STILL DISPLAYS “F” ON THE SAME
TANK, REPLACE PRINTED CIRCUIT BOARD.
(B) IF STEP (2) ABOVE DISPLAYS “F” ON DIFFERENT TANK,
THEM THE PROBLEM MAYBE A SHORT IN THE WIRING, A
SIGNAL WIRE SHORTED TO GROUND WILL DISPLAY “F”
ON THE PANEL. REPAIR OR REPLACE WIRING.
My money is on you swapped the ground for a signal wire.
Horst Miracle Probe 5th Wheel Install #1
ID:	15867   Click image for larger version
Name:	Horst Probe Install 008.jpg
ID:	15868   Click image for larger version
Name:	Horst Probe Install 035.jpg
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 100 views)
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (51.2 KB, 53 views)
HAM CALLSIGN - KC3FFW
Old 06-29-2012, 12:03 PM   #5
jimh's Avatar
there is another item. where three of the wires attach to a small (postage stamp sized) box before the wire goes to the panel. when one of mine was showing full, someone at the factory pointed to that item. don't see how u could have damaged that unless it was pulled on.
if any part of it is still working. the only problem is the one tank, i would verify everything else to be right before replacing a board. if that board is in the display panel, i would think it would be dead on all tanks. i'm a little hard headed abt looking at something other that what i did to stop something from working.
the board may be ur problem but i would try and prove that before buying another. if all u did was swap probes but it was otherwise functioning, i would tend to look elsewhere first. when i couldn't find anything, i would take a bowl of water and place the common lead and then each of the other wires (individually) in it to see it anything changes.
make sure u didn't break one of the wires in the process of tightening them down.
Old 06-29-2012, 02:15 PM   #6
acadianbob's Avatar
I'd like to try this mod but my trailer has an enclosed underbelly. I'm kind of reluctant to try taking it down. Has anyone done this? If so, I'd like to hear of your experience with it.
We have been using PurePower enzyme additive in the black tank. This year I've been trying the GEO method and driving with just a few gallons of water, softener, and detergent in there trying to clean things up. But no luck so far. Black tank still shows full no matter what.
I suppose I could save myself the trouble and expense just by looking down the toilet bowl!!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 06-29-2012, 02:52 PM   #7
jimh's Avatar
i have the probes and have been wanting to make the modification. i also have the underbelly enclosed. went in from the top and found that i would have to drill holes (the old probes are bonded in). even with a close quarter drill, i didn't have enough room to get between the sewer out line and the tank.
couldn't see how the sewer out line was attach so it's on hold. i noticed from the pictures on herk's that it appears there is a hose clamp holding it. i may tackle it after all.
underbelly has a section that is removable below the tanks. i'll lower that next. it will be on my bucket list.
i've had success getting my black sensor to show zero after massive flushing. it is short lived though, first flush and all the way up.
Old 06-29-2012, 03:04 PM   #8
Herk7769's Avatar
Jim, that "box" is a resistor pack.
See the attached diagram. As the indicators are submerged the resistor pack finds grounds and changes the resistance of the circuit. That is why a shorted signal wire will always show "FULL"
Are you sure that they are "bonded" in? There is a rubber compression washer on my old probes. A pair of side cutters were all that was required to wiggle them out. Be sure to push the old threaded part into the tank a little ways to provide room for the compressed rubber to collapse and allow withdrawal of the probe.
Old 06-29-2012, 03:09 PM   #9
Herk7769's Avatar
Anyone having probelms with their indicators need to look at the Horst probe video AND read the troubleshooting guide I attached to my first post in this thread. It is all the way at the bottom.
Old 06-29-2012, 04:14 PM   #10
jimh's Avatar
didn't know what it was. makes sense to limit current an more probes are flooded. do u happen to know if they are the same value for grey or black? looks like the black would much more conductive.
