Old 04-01-2013, 03:10 PM   #1
comish4lif's Avatar
Question Replacing Tow Connector (?) Cable
Greetings,
Last fall, on my last trip, I didn't properly suspend my connector cable and scraped through the covering and some of the wires. I am talking about the 7 pin connector that links the tow vehicle to the trailer (lights, signals, brakes, etc). It is wired directly to the camper and plugs into the tow vehicle.
I want to order a new one and am not sure about how much of a job replacing it is. If I wanted to get it done, who/what kind of repair person is going to be my safest bet? The nearest RV dealer is more than an hour away.
'09 Rockwood Mini-Lite 2306
Towed w/ '09 Nissan Frontier
comish4lif is offline   Reply With Quote
Old 04-01-2013, 03:43 PM   #2
rattleNsmoke's Avatar
I've never done one but it wouldn't stop me. If you're confident around hand tools go for it. It can't be rocket science.
rattleNsmoke is offline   Reply With Quote
Old 04-01-2013, 04:01 PM   #3
woodsman's Avatar
I did not attach mine correctly on NE trip several years ago. I had to rewire the connector to the pin and wire coming out of the TT. After having it done by the "PROS" and then having to redo it, I ordered the exact wire and had a friend put it on correctly. No further problems. If you do not do it right then you can expect problems down the road. The exact cable is the bst way to go and is easy to replace as long as its not inside a covered under belly. Videos are on the net on how to's
Took several hours at sundown to rewire cable. A pro can do it in an hour.
woodsman is offline   Reply With Quote
Old 04-01-2013, 09:25 PM   #4
TURBS's Avatar
The cable coming from your camper can be replace easily.
Go to any parts store and order the length you need plus a little extra just incase and the plastic 7 way plug.
The trailer end will be tied together inside a metal household wiring box .
Replace wires one at a time in the junction box .
If your plug in end is all molded together then this will help.
7 way Bargman plug wire diagram.
good luck and remember were always here to help.
TURBS
Old 04-01-2013, 09:41 PM   #5
wv campers's Avatar
I replaced mine last year. Got mine at camping world. Easy to replace. You should have a junction box under the camper. Detach the wires and splice the new one. The wires should be color coded to match up. I pinched mine between the tongue of the camper and my bumper when I was backing into my site.
wv campers is offline   Reply With Quote
Old 04-01-2013, 10:02 PM   #6
Good idea to disconnect trailer battery before starting that job just to be safe and not short out your battery.
X2 on wires being color coded.
Ken & Janet
'07.5 GMC 2500 D/A CC/SB
'09 SABRE 31RETS-6
wingriders is offline   Reply With Quote
Old 11-01-2014, 03:46 AM   #7
Bakka323's Avatar
To tag onto Comish4life's post. I have a travel trailer and at some point, backing in the trailer I pinched the 7 pin trailer cable and nearly cut through the entire wire harness. The cut is near the middle of the cable and there is enough slack to splice together the 7 pin connector. What are your thoughts regarding splicing the cable together vs. replacing the entire 7 pin cable? Any splicing or cable replacing tips would be very helpful.
2006 Nissan Xterra 4X4
2013 Surveyor SP-189 Cadet
Bakka323 is offline   Reply With Quote
Old 11-03-2014, 05:07 PM   #8
I like waterproof butt connectors of the correct size for splicing wire. You will have a considerable thickness bulge if the splices are aligned together. I also do not hesitate to use additional heat shrink adjacent to the connectors to strengthen the wire. I judiciously use a paint stripping heat gun for shrinking the heat shrink (hair dryers also work pretty well) without melting wire insulation.
just my experiences
Fred W
Old 11-03-2014, 05:29 PM   #9
B and B's Avatar
If splicing a length cut all wired different lengths to avoid the spice budge. you can then use self vulcanizing rubber tape to cover the connections. This will bond and keep the water out.
Then cover the rubber tape with Vinyl electrical tape after .
I like 3M tapes. To start the vinyl tape start a 1/4 in and the wrap over the end and all the way and back up keeping tight pressure.
I if was doing it i would solder the wires use water proof heat shrink (has glue inside it) then wrap with vinyl tape. Need at least 250 watts (or more) on an American Beauty solder iron and good Kester solder.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-04-2014, 06:37 PM   #10
Bakka323's Avatar
Thanks Fred and Brian for the great advice! I'll keep you posted on how it goes...
