10-16-2014, 08:28 AM
Reset time on EMS surge protector
I have a 2015 Hemisphere 282rk with a 15k btu ac by Dometic (I think).
I recently installed an EMS by progressive industries. It will cut the power to the trailer during power surges. By default power is restored within 15 seconds but the owners manual says that I can change that to 2 minutes if my AC shouldn't be restarted that quickly. I'm paraphrasing here but those with an EMS know what I'm talking about.
So can I leave the EMS at the default 15 seconds?
10-16-2014, 08:31 AM
As long as your a/c recovers in that 15 seconds I'd leave it.
You can put a hard start capacitor in the a/c to help this.
iirc you cut a wire inside unit for the longer duration.
Turbs
10-16-2014, 08:40 AM
Btw mine is @ 15 seconds
Turbs
10-16-2014, 08:51 AM
Read your a/c or thermostat manual and find out what if any time delay they have built in for power loss/restarting. My dometic unit has a two minute delay built in so I run the 15 sec delay on the ems
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
10-16-2014, 08:59 AM
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
10-16-2014, 09:02 AM
I've read AC owners manual and see no mention of delay. Help please
10-16-2014, 09:05 AM
Which surge protector do you have?
10-16-2014, 09:08 AM
Originally Posted by mud yapster
Yes it should have.
Turbs
10-16-2014, 09:12 AM
Yes I know it should have but it didn't come with the jumper but its no biggy I have time delays built in on my A/C units
10-16-2014, 09:17 AM
Progressive Industries HW30C
10-16-2014, 09:18 AM
Dometic AC Model 57915.531G1
Turbs
10-16-2014, 09:20 AM
There's your answer Elton
10-16-2014, 09:22 AM
I've got that but I can't find what my AC time delay is.
10-16-2014, 09:23 AM
I've got that but I don't know whether to leave at 15 seconds or move to 2 minutes.
10-16-2014, 09:24 AM
my A/C delay is built into my electronic thermostat. I have 2 A/C units operated off the same electronic stat.
Regardless if you change it to the 2 minutes your safe either way![emoji106]
Turbs
10-16-2014, 09:38 AM
The directions say to move it to 2 minutes if there isn't a delay on the ac. The EMS is set to 15 seconds at factory. I don't know what the time delay is on ac
10-16-2014, 09:40 AM
Is set it to 2 min. then so your safe
10-16-2014, 09:43 AM
I realize that. Didn't want to set to 2 min if I didn't have to.
