Old 08-21-2015, 04:17 PM   #1
Taranwanderer's Avatar
Reverse polarity at pedestal
So I get to camp, plug my surge guard into the pedestal, and it comes up "reverse polarity," so of course, it won't allow the power to turn on. The outlet on the other side is the same way, but the one at the next site the other way is OK. So will this damage my camper if I plug in without the surge guard? Is it a matter if hot and neutral being switched, and what can happen if it's used in that condition? TIA...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-21-2015, 04:23 PM   #2
May or may not cause damage, but I for sure would not plug into it. There is definitely a safety issue there.
Papa GLS is offline   Reply With Quote
Old 08-21-2015, 04:38 PM   #3
fonzie's Avatar
Here some reading on reverse polarity......
The shocking truth about campground electricity
Fonzie
Old 08-21-2015, 04:50 PM   #4
wmtire's Avatar
Mike Sokol (our RV electrical safety guru), went over this fairly recently in this thread:
Electrified???
P.S. I also recommend reading that entire thread linked above. It could save members problems in the future.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-21-2015, 05:08 PM   #5
Thanks for all the replies.
So after a few minutes of the surge protector being plugged in, the reverse polarity warning decided to stop. I'm guessing there may have been some residual current somewhere in the ground, or pedestal, since we got a lot of rain here last night. Or maybe Venus was in the improper alignment momentarily. It's working fine now. Go figure.
Old 08-21-2015, 07:10 PM   #6
Reverse polarity is not something that just goes away; it is a physical wiring issue. Your surge guard may be the problem.
Old 08-21-2015, 07:19 PM   #7
Who Dares, Wins
doc73's Avatar
Not an electrician so go easy... But could someone plugged on down stream somewhere that is incorrectly wired be back feeding the system? Do not know if this is possible just a curiosity.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 08-21-2015, 07:22 PM   #8
fonzie's Avatar
No not possible......
Fonzie
Old 08-22-2015, 09:11 AM   #9
Or no reverse polarity exists. Reverse polarity is implied when a voltage between neutral wire and safety ground wire is too large. How large? Well, that voltage difference may occur when a neutral wire is carrying too much current - therefore has a small voltage difference. No reverse polarity exists. But that voltage difference is enough for a surge guard to suspect it exists.
To say more means numbers from a meter must be provided, All this is layman simple once one learns the simple relationships between those AC power wires.
westom is offline   Reply With Quote
Old 08-22-2015, 09:26 AM   #10
Reverse polarity is when the hot and neutral legs are reversed. This will not damage an AC appliance but it is a safety issue.
Brewhedd is offline   Reply With Quote
