Old 10-02-2011, 03:38 PM   #1
Reversed battery poles
I VERY stupidly reversed the poles when I reconnected the battery in my Flagstaff trailer. I have replaced the forty amp fuses in the panel but still am unable use battery power even if connected to the truck. Everything works fine when connected to 120 volt power. Is there something I may be missing? Thanks very much.
Brian Pate is offline   Reply With Quote
Old 10-02-2011, 03:47 PM   #2
I did the same stupid mistake on my minilite this summer and also blew the 40 amp fuse in the converter. There is a note posted in the converter cover that the 40 amp fuse will blow if the battery is connected wrongly. But to tell you Brian after I replaced the fuse all went okay with no after shocks problems. You must have blown another fuse in the line for the 12 volts. Good luck. For me I have my lesson now!!!
capucine is offline   Reply With Quote
Old 10-02-2011, 04:01 PM   #3
acadianbob's Avatar
No more to add other than I did this once too . . . Blew the same reverse polarity fuse. Also blew a fuse in my sound system.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 10-02-2011, 04:13 PM   #4
Check the batery disconnect switch and also check for any resettable breakers that may have tripped.
Old 10-02-2011, 05:06 PM   #5
Herk7769's Avatar
An "out of the box" thought. If your battery was low to start with; the short might have reduced the voltage to a point where the converter is shutting down due to the low voltage on your battery.
Remove the battery again and put it on a charger.
Try again (connecting it correctly).
HAM CALLSIGN - KC3FFW
Old 10-02-2011, 08:38 PM   #6
BaronBigDog
Reversed polarity
You may have a bigger problem. The 110/12 charging unit in my Flagstaff is fragile at best. I just replaced it and I did not reverse anything. It just got silly. I noticed brightening and dimming of the lights and called my dealer. The parts person already knew the model and part number when I explained my problem. Kind of makes me believe that the unit (made in China) is kind of feeble. The parts person response to me when I mentioned that she knew the part number off the top of her head was a chuckle and "now how did I know that?"
In any event if you need a new unit the dealer may not be your best option. I got an entire unit on E bay and changed out the lower end myself. Took about 20 minutes. Now it is working OK. I paid 119. My dealer wanted 238.
BaronBigDog is offline   Reply With Quote
Old 10-02-2011, 10:19 PM   #7
Herk7769's Avatar
If it turns out to be the WFCO unit, you might investigate higher end 4 stage units as a replacement. They might not fit the cut out so you might have to make some cosmetic changes to install it.
Old 10-02-2011, 11:40 PM   #8
TURBS's Avatar
I replaced my wfco converter with an intelli power converter but used my wfco housing and electronics. Had to do some minor mods to housing but it worked great.
I also purchased the charge wizard and went from a 55 amp to a 70 for less money.
Pm me for more info
Old 10-03-2011, 07:48 AM   #9
KyDan's Avatar
OP says he still has no 12v power even when connected to his truck.
Says he is unable to use battery power.
He doesn't specify if the converter is working or not.
Could be a blown battery fuse or tripped reset in the tongue area. These battery fuses are commonly found underneath near the front end
of the trailer.
Good Luck!
I once witnessed a guy at work install a battery in a golf cart backwards.
It exploded with enough force to bounce the battery cell caps off the
ceiling of a 40 foot high shop. He didn't get any acid in his face
but I don't know why not.
Always wear glasses and stand back when connecting your batteries!!
Be careful out there.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 10-03-2011, 07:54 AM   #10
Herk7769's Avatar
Check these out
Helped a fellow camper (now a forum member) after hearing a huge explosion. His MH had a frozen (dead) battery and when he was running the MH to charge it... Wham.
ID:	8279   Click image for larger version
ID:	8280   Click image for larger version
battery
