Old 09-02-2016, 07:16 AM   #1
Kingair's Avatar
Rock wood 2504
Where is the electrical control module located?
2017 Columbus 385FL
2017 GMC 3500 HD Dually
Kingair is offline   Reply With Quote
Old 09-02-2016, 07:42 AM   #2
craigster_mi's Avatar
if you mean the control panel, its on the end of the upper cabinet over the sink
craig
2018 F150 Eco
2015 Rockwood Mini-Lite 2504S
craigster_mi is offline   Reply With Quote
Old 09-02-2016, 08:22 AM   #3
Kingair's Avatar
No the electrical converter I have lost all AC power and the last things to check are that and the cord itself.
2017 Columbus 385FL
Old 09-02-2016, 08:32 AM   #4
I believe its under the refrigerator. Push on the door and it springs open. hope this helps, if not I hope someone else that knows chimes in so i'll know too.
craig
2018 F150 Eco
Old 09-02-2016, 08:35 AM   #5
That is where mine is on our 2504. All the fuses and breakers are there. What do you mean lost a/c power? Do you have power at the post? Jay
Jay2504 is offline   Reply With Quote
Old 09-02-2016, 09:04 AM   #6
Kingair's Avatar
I have power to the post, blue light on the female side of power cord. No power to slide, awning, microwave etc. Tried gender and 30
Amp house power. I opened the fuse panel and found the converter. There's is a ceramic
Fuse inside. All other fuses and beakers are good.
2017 Columbus 385FL
Old 09-02-2016, 09:30 AM   #7
The slide runs off 12volts. The microwave runs on 120volts. Is the battery turned on? If so could it be dead? I have never plugged in to shore power with the battery turned off but I think that the microwave would still work. Is there power at any 120 outlet in the rv? Check the ground fault on the outlet by the door. Try a ceiling light to see if it comes on. If you left the battery on and the camper not plugged in in a few days the battery will be dead. Ask me how I know. Jay
Old 09-02-2016, 10:24 AM   #8
Kingair's Avatar
Rock wood 2504
I pulled out the converter and tested the pictured fuse; no good. Does the power pass between this module? I get 120 volts to the board.Click image for larger version
Name:	ImageUploadedByForest River Forums1472829816.971821.jpg
ID:	119224Click image for larger version
Name:	ImageUploadedByForest River Forums1472829829.205155.jpg
ID:	119225Click image for larger version
Name:	ImageUploadedByForest River Forums1472829841.608375.jpg
2017 Columbus 385FL
Old 09-02-2016, 10:48 AM   #9
I have never pulled mine apart. Are your batteries dead? Just a thought, the fuse blew because the battery is completely dead or bad. Do you have any power on the 12volt side? If not check the voltage directly at the battery. Hopefully someone who has converter experience will chime in. Jay
Old 09-02-2016, 10:55 AM   #10
Kingair's Avatar
The guy who installed my 30
Amp did 220 volts instead of 120
2017 Columbus 385FL
Old 09-02-2016, 11:10 AM   #11
I take it that you are talking about the 30amp plug that the TT plugs into? Did you have one put in at home? Jay
Old 09-02-2016, 11:14 AM   #12
Kingair's Avatar
Yea he installed one at home but made it 220.....oooops.
2017 Columbus 385FL
Old 09-02-2016, 12:10 PM   #13
Glad you found the problem. 220 volts to the camper could result in a "bad hair day". Jay
Old 09-02-2016, 02:37 PM   #14
bikendan's Avatar
Kingair, this happens way more than you would think.
There are tons of threads and posts of this happening.
We always try to warn those having a home hookup installed, that this often happens.
But they have to ask for help/info BEFORE the electrician starts.
You may have more damage than just the converter.
