Old 12-20-2015, 08:36 AM   #11
I try again today to remove the old switch, replacing the complete assy. sounds a lot better! Thanks.
kg4lrd is offline   Reply With Quote
Old 12-20-2015, 12:51 PM   #12
If need be turn power off and use a chisel to get old switch out. Install new switch Disconnect wires and install on new switch.
Harkerr is offline   Reply With Quote
Old 12-20-2015, 01:19 PM   #13
Problem solved. With a little "destructive" effort the switch comes out of the front of the housing, the back does not pull off. The old switch was green and corroded, water problem. After it drys out, DW40, I will install the new one. Thanks
Old 12-20-2015, 03:40 PM   #14
A32Deuce's Avatar
I would use dielectric grease on the connections before putting back together.
A32Deuce is offline   Reply With Quote
Old 12-20-2015, 03:56 PM   #15
Find a way to keep water out or you will repeat this.
Old 12-20-2015, 04:05 PM   #16
onetonford's Avatar
On the backside of mine is on the skirt and rear wheel would throw water on the switch. Real good engineering so I cut hole in side of a plastic instant coffee jar to fit switch inside ran wires out the bottom and sealed it with silicone to the skirting. screw the cap on and I got a water proof switch with access.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 12-20-2015, 05:55 PM   #17
Left Coast
Get a plastic compartment with dood and put it under cover (inside the compartment) Easy to enlarge the existing hole for the recess of the compartment
Old 12-21-2015, 03:31 PM   #18
Jack350's Avatar
I replaced my switch that was located in the front of my RV. I just hooked up the wires to the new switch and used electrical tape and located the switch inside the storage door. I have the old switch back in the original position to fill the hole. Now there is no water problems and my switch is in a locked area.
2012 Crusader 26RLD, 2017 F-350 4X4 6.7.
Hayes Autoformer, Correct track, Maxxis 8008E, Andersen Aluminum hitch.
Jack350 is offline   Reply With Quote
Old 12-21-2015, 03:54 PM   #19
A32Deuce's Avatar
Good deal!
Old 12-21-2015, 03:55 PM   #20
Left Coast
Here's my rear oneClick image for larger version
ID:	96592 Front switch soon, also.
Sent from my XT1080 using Tapatalk
