Old 12-20-2015, 07:12 AM   #1
Rocker Switch for stabilizer extend/retract gear
The switch went bad and they sent me a new switch but I can't get the old on apart, or I don't know the secret. It looks like it is a molded back but is supposed to come apart/slide off, then the switch is to slide out so it can be replaced. I can't get it apart and don't want to use too much force. Any input?
kg4lrd is offline   Reply With Quote
Old 12-20-2015, 07:15 AM   #2
Can you pop it out from the back side of the switch?
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 12-20-2015, 07:19 AM   #3
bubbles's Avatar
From the back side of switch pinch the top and bottom tabs and it will come out the front of panel.
Old 12-20-2015, 07:23 AM   #4
F/R replaced my O/E rocker switch's that (Stuck) when used with New style switch's rubber covers! They removed the entire O/E switch's and Installed Complete New switch's,they used Nothing OLD but the wires that simply Plugged into the New switch's! Youroo!!
Old 12-20-2015, 07:27 AM   #5
I tried getting the back off and it wouldn't move. The RV service guy said to took a bit of force but it wouldn't budge.
ID:	96471   Click image for larger version
Old 12-20-2015, 07:31 AM   #6
Pickin' & Campin'
Post a photo of the replacement.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 12-20-2015, 08:06 AM   #7
New switch
Old 12-20-2015, 08:09 AM   #8
Pickin' & Campin'
I would say it does not appear the square plastic housing on the back of the switch comes off. You'll need to somehow depress the tabs on the original switch (likely from the back through the housing) and remove the original switch by pulling forward out of the housing. The new switch will then snap back into the housing.
Old 12-20-2015, 08:13 AM   #9
Pickin' & Campin'
I've marked the tabs you need to release to get the original switch out.
Maybe use a thin screwdriver or ice pick type of tool.
Old 12-20-2015, 08:18 AM   #10
The Entire Assy.needs to be removed to access the wires any way,so have F/R send you the COMPLETE Assy,NOT just the Rocker switch! Youroo!!
