Does anyone know if the 2019 2706WS has a battery disconnect switch? I have looked at the owner manual and it leads me to believe it does but doesn't give a location. Does anyone know where it might be located if there is one. Thank you in advance for any help offered.
Just keep in mind that there could be things that bypass the disconnect switch. The LP/CO detector comes to mind, as well as the memory power for the audio system. Might want to check those and see if they're still powered when you open the switch.
Gotta go campin!
I decided that the cheap key switch and the factory installed location was inadequate. I upgraded the cutoff switch and mounted it on the forward wall of the pass through where I can easily access it and use the 12v supply to power my air compressor.
