Old 08-28-2016, 09:09 PM   #11
Learning a lot as I go...
Short term with small extension cord will not hurt much. Especially if nothing was on or working.
Cannot say it works for all... but I often find when the 110v stuff in the trailer is not working it is because the GFCI in the trailer has tripped. I reset it and the TV comes back on (the main thing we use on 110v in the trailer).
Prior suggestion about testing house outlet then plug in cord and test cord was a good one.
stevejahr is offline   Reply With Quote
Old 08-28-2016, 09:13 PM   #12
I'm going to get a a new corded suggested earlier and try it. All I have now and what I used was a 150 ft regular extension cord
Puma newbie is offline   Reply With Quote
Old 08-29-2016, 01:19 PM   #13
If you are on an extension cord... best thing you can do is A) do not run AC and B) do not run hot water on electric. Those two are your largest 110v draws and everything else should be fine on the extension cord.
Old 08-31-2016, 08:50 PM   #14
thanks to all for the help I was just able to get the proper extension cord. once I got it all seems to be working well.
roo
