Old 08-28-2016, 07:24 PM   #1
Rookie mistake
I plugged my rv in to my home with a regular extension cord and nothing worked. I even tried to flip ac thermostat on. Once I realized it wasn't working in unplugged it. It didn't flip any breakers in the rv or house and the cord wasnt hot. Afterward I did some reading and found out I need a a different extension cord and running an ac isn't recommended. I feel like an idiot hopefully some experts out there can share there knowledge and experience tell me I should be ok.
Puma newbie is offline   Reply With Quote
Old 08-28-2016, 07:30 PM   #2
A little confused. Do you have the adapter to take your 30 or 50 amp plug to a 15 amp? If so everything should work. I would not run the ac but everything else should.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 08-28-2016, 07:33 PM   #3
I did use a 30 amp to 15 amp adapter. I think my problem was I use a 100ft regular extension cord. Just fear I screwed something up.
Old 08-28-2016, 07:34 PM   #4
Then it should be working. No microwave or outlets work?
2016 Flagstaff 23lb
Old 08-28-2016, 07:36 PM   #5
Ford Idaho's Avatar
I use this to plug in the lite, have used smaller gage ones for a short time.
From lowes for 100 bucks.
Utilitech 50-ft 20-Amp 110-Volt 10-Gauge Yellow Outdoor Extension Cord.
Turning on the AC will pop a breaker but everything else works fine.
Old 08-28-2016, 07:41 PM   #6
Flybob's Avatar
Check the outlet in the house that you used. If it is on a GFCI it is likely you tripped it as many of them do not like being connected in series. If it is a newer house and is an outside or garage outlet, it should be GFCI protected. Note the protection be via a GFCI breaker in the master panel. You can test this by plugging a light into the end of the extension cord that you used to connect the TT. You should be OK as far as damage goes unless you left power on for a while.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-28-2016, 07:48 PM   #7
Sounds like I may be ok the garage plug I used wasn't tripped. I don't think it was plugged in for even 10 mins. Thanks for your reply.
Old 08-28-2016, 07:49 PM   #8
They didn't
Old 08-28-2016, 07:51 PM   #9
Could be the problem was the cord wasnt 10 Guage and too long
Old 08-28-2016, 07:52 PM   #10
Test the plug you have the extension cord in with a light or radio to make sure it works. The test the extension cord the same way. Then plug it in and test an outlet in the trailer the same way.
2016 Flagstaff 23lb
roo
