Old 02-09-2013, 04:37 PM   #1
Run on 30Amp @ Park w/ 50amp service?
Just got a 34TBOK w/ 50 amp but do not have the 2nd A/C and only 10 gal gas/electric water heater - do you have to run on 50 amp at the parks or are you OK to run on 30 amp since no 2nd A/C?
kritta is offline   Reply With Quote
Old 02-09-2013, 04:38 PM   #2
TURBS's Avatar
Your ok running a dog bone 50 to 30 amp adapter.
Normally the 50 amp service is for second a/c
You most likely have second a/c prep.
Turbs
Old 02-09-2013, 04:55 PM   #3
So if campground has 30 amp & 50 amp service - and the 30 amp spots are better - is it really OK to run on 30amp or will there be harm done to anything at all for the whole season?
Old 02-09-2013, 05:05 PM   #4
Tailwind's Avatar
You would be fine. The amperage rating is just what is available, not what you are using. Without a 2nd AC, you should not use over 30 amps. If you somehow do, the breaker on the campground box would trip, no damage to your unit.
2012 F-250
Flagstaff 8528IKWS
Tailwind is offline   Reply With Quote
Old 02-09-2013, 05:12 PM   #5
TURBS's Avatar
it is really ok .
And normally the extra 50 amp leg only runs the second a/c which you don't have.
good list to have .
normal appliance amp draws
Old 02-09-2013, 06:31 PM   #6
We ran our 50 AMP cord off a 30 AMP campground pedestal using a dogbone adapter all last summer without any problem. BTW we've got 2nd AC ready but no AC in the bedroom either.
Old 02-11-2013, 07:38 PM   #7
Hope I'm not hijacking thread. New owner of Rockwood 1905, maiden voyage this spring. With minimal use of heat & one A/C unit, microwave and given use of fridge, lights, stereo on shore power can we get by on 15 amp service or should we be looking at 30 amps?
Thanks, Norm
2016 Silverado 5.3L Z71 with tow package
2012 Rockwood Mini Lite 1905
Distribution Hitch: Trunnion
Nammy is offline   Reply With Quote
Old 02-11-2013, 07:39 PM   #8
Oops, forgot to mention water heater & pump...
Old 02-11-2013, 07:54 PM   #9
Herk7769's Avatar
Thanks, Norm
Heat requires more than 15 amps since the heater alone pulls 15.5 amps.
The air conditioner also runs about 14-15 amps depending on size.
Forget the rest (stereo, TV, etc) if you only have 15 amps available.
Get the 30 amp site if you can.
HAM CALLSIGN - KC3FFW
Old 02-11-2013, 08:05 PM   #10
Thanks herk, that's what I thought. Got a lot to learn about this stuff.
