Old 06-21-2016, 06:55 PM   #1
RV charging battery
I am new to Rving and have my batteries plugged in but not sure if I am to push the USE or STORE button while charging. Also, I was told I could leave it plugged in but need to check the water level about every 6 months. I will be taking her out for the 4 th.
thanks
NolaGurl
lynnec54 is offline   Reply With Quote
Old 06-21-2016, 07:18 PM   #2
Jerry01's Avatar
Not sure what the use or store button is. Maybe a battery cutoff switch? Either way if want to charge your batteries, press the use button or switch the battery cutoff switch to on. Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 06-21-2016, 08:01 PM   #3
Thank you. I am sure the USE is for on. I was just making sure it was alright to keep it plugged and check water level in between. This was very helpful.
NolaGurl
Old 06-21-2016, 08:02 PM   #4
bikendan's Avatar
thanks
NolaGurl
It would help if you posted make and model of RV you're asking about.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-21-2016, 08:09 PM   #5
Yes that would help. It is a 2005 Forest River Lexington class C.
battery, charging
