Old 05-21-2018, 08:19 PM   #1
RV GFI - same as residential???
Hi:
Looks like I have a GFI that's on the way out in my Wildwood.
OK to replace with a quality residential version or is there something special about a RV version?
2010 Wildwood XLite 26BHXL
2013 Ram Outdoorsman 5.7l
Ontherock is offline   Reply With Quote
Old 05-21-2018, 08:36 PM   #2
llr
Except for the residential being better quality the only possible issue I see is it could be larger. If you have space go for it
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
llr is offline   Reply With Quote
Old 05-21-2018, 08:38 PM   #3
Flybob's Avatar
There is nothing special about RV GFCIs
The only thing you need check is the box. RVs sometimes use shallow boxes and a standard outlet may not fit. When replacing, use the screws vs the punch down connections.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-21-2018, 08:39 PM   #4
I wouldn't think any thing used in the rv manufacturing process would be overly spectacular. Plug depth could be an issue as stated. Most rv boxes are very shallow. I'm sure you are aware that sometimes many outlets are wired off the same GFI.
Kimber45 is offline   Reply With Quote
Old 05-21-2018, 09:20 PM   #5
Thanks for the replies and I appreciate all the suggestions!
I plan on removing it next weekend to have a look so I thought I'd replace it while I was at it with one from the local hardware store.
Thanks!
Old 05-22-2018, 01:28 PM   #6
GFCI outlet replacements
Cooper industries also makes a GFCI box extender if there is a depth issue
masterglenn72 is offline   Reply With Quote
Old 05-22-2018, 01:50 PM   #7
Thanks for the info!
Old 05-22-2018, 04:09 PM   #8
Post
Originally Posted by Ontherock View Post
Hi:
Nothing special.
I changed out my main GFCI, (Ground Fault), receptacle for an AFCI, (Arc Fault), which is much safer, (guarding against internal arcs, preventing fires).
https://www.amazon.com/Leviton-AGTR2...eceptacle&th=1
Seems to work very well
Cuban Crisis Vet
2017 Forest River SunSeeker 3050S
Ford 450 Super Duty
Just me and the Wife
emeth is offline   Reply With Quote
Old 05-22-2018, 06:24 PM   #9
You should keep the GFCI protection if it had it from the factory( per national electric code.). Arc faults are not the same as ground faults. If you want the extra protection, they make a combination arc and ground fault unit.
Old 05-22-2018, 06:50 PM   #10
Villagerjjm's Avatar
It happens!! Pull it, then look inside the wall box. Measure for size!!1
Villagerjjm is offline   Reply With Quote
Old 05-22-2018, 07:02 PM   #11
Post
The link I included is a combination GFCI and AFCI.
Dual protection, (the factory is less concerned about arc fires and only provides GFCI protection).
Cuban Crisis Vet
Ford 450 Super Duty
Old 05-23-2018, 01:56 PM   #12
emeth:
How did it compare size wise with the original GFI?
Old 05-23-2018, 08:01 PM   #13
emeth:
Same size for my installation, however, if necessary, just remove the surface box the original is in and replace it with a slightly deeper box which are available and look even better than the original.
I believe that the GFCI/AFCI receptacles come in white and black
Cuban Crisis Vet
Ford 450 Super Duty
Old 05-24-2018, 09:18 AM   #14
emeth:
Great upgrade suggestion!
I'll see if I can get one locally. If not, I'll probably order one in.
