Old 10-19-2014, 10:25 AM   #1
RV monitor panel for tanks Problem??
Hello agian,
I have a problem my trailer is now parked for the season however it is still plugged into my home. I check the battery levels and tanks levels and it is like their is no power going to the sensor monitor panel, it lights up barely, quick, like a flash then it is completely black??? Like no power. I still have lights, radio etc but the panel is reading nothing. Any ideas?? Thanks!!
tbeefitz is offline   Reply With Quote
Old 10-19-2014, 11:28 AM   #2
Evereddie's Avatar
Even though lights and radio work it could be low voltage in your 12 volt system. Hopefully you have a test meter and can see what the voltage is at your battery. With the trailer plugged in the on board charger should be reading 'around' 13.5 volts on the battery. If that is good look for fuses, loose wire? Can you pull off the sensor panel; and look around behind it for anything loose.
Evereddie is offline   Reply With Quote
Old 10-19-2014, 11:34 AM   #3
Thanks. But I made a boo boo:/ I forgot I removed the fuse for the LP I
Guess they run on the same circuit because soon as I replaced it it works fine.
Thanks again,always learning
Old 10-19-2014, 01:27 PM   #4
Evereddie's Avatar
That's the best solution, nothing was really wrong. Glad it worked out.
tank
