Old 02-04-2013, 05:55 PM   #11
Herk7769's Avatar
Lots of pertinent information in this article.
HAM CALLSIGN - KC3FFW
Old 02-04-2013, 07:20 PM   #12
Canadian Member
itat's Avatar
I know very little about electrical circuits but how can you have reverse polarity on an AC circuit? And what are the other conditions that the meter is testing for?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 02-04-2013, 07:56 PM   #13
caper's Avatar
Reversed polarity is caused when the hot and common wires are reversed. The new two prong plugs have a blade that is larger then the other. This is so you can only plug the cord in one way. You can also have a bad ground or no ground. The post could also have high or low voltage.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-04-2013, 08:08 PM   #14
Herk7769's Avatar
Here is an article that will explain it better than I can.
File Type: pdf Alternating Current and Why Polarity is Important.pdf (100.5 KB, 44 views)
Old 02-04-2013, 09:41 PM   #15
Canadian Member
itat's Avatar
Thanks, guys. I found the BoatUS site and got lots more info on this topic. I've ordered the Prime Products 12-4058 AC Power Line Monitor and I'll use it before connecting every time.
Can I use it at the power pedestal to check polarity before connecting and then plug it in inside to monitor voltage?
What's your experience when you find a problem with a pedestal, either with the polarity or voltage?
Old 02-05-2013, 06:06 AM   #16
Herk7769's Avatar
Polarity has been usually OK.
I have had many problems with incorrect voltage (both low and high).
My Franks unit has saved my bacon on more than one occasion.
