Old 09-28-2016, 05:12 AM   #11
World Wide Wanderer
wahoonc's Avatar
Originally Posted by mnolasco View Post
I just bought a PI ELECTRICAL MANAGEMENT SYSTEM HW50c. I have not installed it yet. The instructions allow installing after or before the ATS. I know that after also monitors the generator. are there any other advantages or disadvantages to these two options?? Also, any advice on installing myself or should i have the dealer install??
Interesting... I would put it before the ATS. Typically an EMS won't work with a generator due to the floating neutral.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 09-28-2016, 10:57 AM   #12
Citrus County, Fl.
GL1800Rider's Avatar
Not sure what you mean by "won't work". Mine works fine. I would think of it wouldn't work progressive would not print it in their instructions
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 09-28-2016, 11:04 AM   #13
fonzie's Avatar
On board generators has the neutral grounded, so there should no issues with using Progressive EMS before or after transfer switch....
Fonzie
Old 09-29-2016, 06:37 AM   #14
Witch Doctor's Avatar
KUDO'S to you, most men won't read the manufacturer's installation instructions, but we seem to all have opinions and that's all they are.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-29-2016, 07:16 AM   #15
Fulltime family RVer
I have a comment on my blog post where down one says that Progressive Industries emphatically said their EMS don't work with generators.
http://learntorv.com/what-surge-prot...est-for-my-rv/
I didn't ask PI about it directly, but I think I will email them.
ependydad is online now   Reply With Quote
Old 09-29-2016, 07:31 AM   #16
My PI unit has "not worked" twice and I had to disable (bypass) it. Once the ground connections at the entire beach campground were weak and the other time a weak current did not allow the unit to function. The PI units have a automatic current and ground fault detection. If they read any abnormalities they will not send current to your RV, which is why you bought the unit in the first place. Just doing it's job.
I am not sure about generators, but based on past performance and design, I can see why it would not work with that type of a cyclic power source.
Wheels Down is offline   Reply With Quote
Old 09-29-2016, 11:25 AM   #17
World Wide Wanderer
wahoonc's Avatar
I am basing my "opinion" on quite a few years of experience. Many generators used to come with a floating neutral, and many still do. Unless PI has come up with some method of detecting and bypassing their sensors (possible) it won't work with many generators. Yes some of the newer ones are now bonding the neutral with the ground. Again I think the PI might have a problem with that. I haven't had a PI in a couple of years, however I KNOW that my current SurgeGuard will not work with any of the generators I have tried it with, RV, Inverter or larger house sized standby.
Also directions are only as good as the manufacturer and person following them make them. I seen many a set of manufacturers directions that went completely against the basic laws of physics, when pointed out the usual response seemed to be, oops or that was for a previous model.
Aaron
Aaron & Rhonda
Old 09-29-2016, 07:29 PM   #18
If you need it you will be glad you have one. What would the cost be to replace your electrical eqipment. I always use one as cheap insurance.
sk734 is offline   Reply With Quote
Old 09-29-2016, 08:09 PM   #19
Another vote for the Progressive unit. I finally came across issue and it did it's job. Low voltage at River Falls at Tallulah Gorge.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 09-29-2016, 08:46 PM   #20
The difference of opinion of the Progressive Industries EMS "Won't Work with Generators" may be because some are talking about a portable generator supplying a trailer and others are talking about an on-board generator that supplies a motorhome through a transfer switch.
The on-board Onan generator on our Sunseeker 3100 supplies power just fine through the factory automatic transfer switch, then through a hard-wired PI EMS-30C.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
