Site team did a thread cleanup here.
The now removed posts didn't really add helpful information and were somewhat combative.
We hope Glen enjoys his new generator what ever brand it is.
I can only add that I believe most modern generators will last a long
time assuming normal maintenance is performed. Modern lubricants today
are a far cry from what we had to pour into the crankcase when I was a lad!
A couple of thoughts that I feel are important to newbys shopping for generators-
Does it have a setting where it will idle when under little load?
(this saves gas AND noise)
Are you comparing apples to apples when you read the db sound ratings?
This one is important-- what distance are they claiming the sound db was measured.
If generator A has a db rating measured at 10 feet and generator B has a
slightly higher db measured at 20 feet- generator B is actually going to be
significantly louder!!
Good luck and happy camping!
