Old 04-16-2017, 04:47 PM   #1
Salem 23T Wiring diagram
i purchased a 2006 Salem 23T travel trailer, which had been repossed and the trailer was GUTTED, charger/converter, monitor, lights, faucets, all appliances, stolen. i have replaced the fridge, A/C, charger-converter, stove, faucets and & lights. now i am replacing water heater and furnace
my problem is i do Not know what furnace or water heater were originally installed i have 3 wires[red/yellow & blue] near the water heater and a thermistat cable + 2 wires[white & green near furnace. also where monitor was a 7 wire cable that should provide tank level data sticks out of wall the monitor i purchased only has 3 water info wires
has any one found a as built/provided list and a wiring diagram. i tried to get information from manufacturer, they told me see the dealer. the dealer said bring it in we'll fix her up !!! which translates to $$$$$$$$$$$$$
Thank You
Name:	23 ft Salem 2006  (4).jpg
HotKreek is offline   Reply With Quote
Old 04-16-2017, 04:52 PM   #2
bikendan's Avatar
Wiring diagrams don't exist.
Old 04-17-2017, 10:10 PM   #3
have made some headway, discovered some more cut-off wires that may be for the water heater. i assumed the H2O heater was a simple gas, but my unit might have had an upgrade to electric ignition.
Old 04-17-2017, 10:59 PM   #4
Broadway Joe's Avatar
Here are two manuals I have for the monitor, hope this helps.
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (56.4 KB, 106 views)
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (152.7 KB, 74 views)
Joe
2015 Wildwood 27RKSS (now sold)
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 04-17-2017, 11:05 PM   #5
Here is all the info I have on the Suburban Heaters
Joe
Old 04-17-2017, 11:08 PM   #6
If you contact the Salem Division rep with your VIN# they can possibly send you a build sheet as it left the factory.
Service
Joe
diagram, salem, wiring
