Old 03-31-2016, 08:31 AM   #11
Head Rambler
Also, have you looked at every receptacle in and around the RV for GFCI's? Ours has one on the outside under the awning and one inside in the bath.
If that doesn't solve the problem, I'd start pulling the receptacles to see if there was a wire that came lose behind one of them. I've seen that happen before.
Gotta go campin!
Old 03-31-2016, 08:50 AM   #12
TURBS's Avatar
Isn't there a gfci in the kitchen as well?
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 03-31-2016, 01:40 PM   #13
Do you have an outdoor kitchen with a gfi? I have gfi outlets inside and out.
Lowes48fan1 is offline   Reply With Quote
Old 03-31-2016, 07:51 PM   #14
3hbenz's Avatar
It's just that one circuit.
3hbenz is offline   Reply With Quote
Old 03-31-2016, 07:53 PM   #15
3hbenz's Avatar
Yes, we have an outdoor kitchen but there's no GFCI there.
Old 03-31-2016, 07:54 PM   #16
3hbenz's Avatar
We have checked in and around, when you say pull the receptacles and check the wires, do you mean behind the fuses or behind the breakers?
Old 03-31-2016, 07:55 PM   #17
3hbenz's Avatar
2008 2500hd Duramax
2015 Columbus 320RS
We couldn't find a GFCI in the kitchen.
Old 03-31-2016, 07:57 PM   #18
3hbenz's Avatar
Old 03-31-2016, 08:25 PM   #19
TURBS's Avatar
Look under the top mount cabinets.
Old 04-01-2016, 06:48 AM   #20
Head Rambler
I meant the actual receptacles themselves. It wouldn't be a bad idea to look at the terminal screw on the breaker either as it could be loose.
Gotta go campin!
electric, electrical, salem
