Old 05-30-2014, 07:25 AM   #1
sat and cable
Is there any way to get a diagram for the cable system and sat wiring for a sierra select 329re. Trying to wire in a sat receiver and out door tv. Also the light and fan in bathroom run off of both switches. Ant idea why i cant just run the fan with out the light coming on
vacationer is offline   Reply With Quote
Old 05-30-2014, 11:05 AM   #2
Retired Trucker/43 years
Noneyerbusiness's Avatar
The light does not have a switch on it? My is wired the same way, but I just turn the light off with the built in switch.
2017 Windjammer 3029W
2006 Ford F-150
HD 7700# tow package
Noneyerbusiness is offline   Reply With Quote
Old 05-30-2014, 12:54 PM   #3
Mine has 2 switches. For some reason they do the same thing. I cant just turn the fan on. The light comes on with either switch.
Old 05-30-2014, 01:29 PM   #4
I have a 2014 haritage glen 300 BH. I have sat tv's at every outlet, including one outside.
I have the direct tv genie system.
The problem I found is the sat signal can't go back through a splitter in the tt. The solution is to use a two way splitter on the sat cable before attaching to the tt.
Then run the 2 wires from the splitter to the tt sat and cable connections. Connect the main genie box to the sat connection in the living room. Use the genie clients at any other cable outlet.
Frank
2014 FR WW Haritage Glen Lite 300BH
1999 F350 7.3 PSD CC LB
96 32' Prowler
96 C2500 EC 454
Frankm2 is offline   Reply With Quote
