Old 07-29-2014, 09:01 AM   #1
Scare Lights Out
I have a 2014 MicroLite 23LB with the LED strip lights just below the awning mount (aka Scare Lights). They have stopped working and I do not see any fuses blown. Has anyone encountered this before? Just want to see if there is an easy fix before I head out on a week trip to the beach.
Thanks!
wdbrady is offline   Reply With Quote
Old 07-29-2014, 09:10 AM   #2
Strip lights and Scare lights are (2) diff.type of lights! Youroo!!
Old 07-29-2014, 09:19 AM   #3
I'm sure my terminology is off. There is a strip of LEDs mounted on the front of the TT just below the awning mount. The switch is labeled Scare Lights.
Old 07-30-2014, 02:36 PM   #4
Evereddie's Avatar
Hmm? I have a Rockwood 2014 2306, essentially the same trailer. My switch is not labeled scare, it says porch and it on the bottom row, second from the left. Anyway, I assume you checked the fuses. There will be a red light on if the fuse is blown. Otherwise I'd take the control panel off and look for a loose wire. I had one come loose in my unit.
Evereddie is online now   Reply With Quote
Old 08-04-2014, 01:45 PM   #5
You were on the right track! Turns out there was a loose wire on the connection at the front of the strip. Thank you!
Old 08-04-2014, 03:12 PM   #6
Evereddie's Avatar
Welcome.
Old 12-04-2014, 10:55 PM   #7
Rcbstuff's Avatar
I have a 2014 19FD and the led strip light on mine is called the scare light. My light has also stopped working , dealer has ordered the parts to repair it, fortunately it is a warranty fix.
Rcbstuff is offline   Reply With Quote
Old 12-05-2014, 09:19 AM   #8
sunnygirl01's Avatar
We just purchased the 2015 21FBRS and ours are labeled scare lights as well. During the PDI the guy pretty much told us they wouldn't work for long. Although I like the look of them, I probably won't drag it back to the dealer when they go out.
***edited to add that I am waiting for someone to post an awesome modification for them because I know the creative minds on here will be at it soon! Lol!***
Steve and Brandi & our "Pit" crew Bella
sunnygirl01 is offline   Reply With Quote
light
