Old 11-20-2019, 03:11 PM   #1
SEPTIC power supply
I want to connect a 100W solar panel directly to my 100a Lithium batteries to charge them using a Power Supply Module Adjustable Constant Voltage Buck Boost Power Supply Module. I am using this septic unit to set the constant voltage to 13.6 recommended by the battery company(Lion energy safari ut battery). The septic power supply came with no owner book. Can anyone tell me what these six parameters should be set to?
input voltage(default set at 4.70)
overvoltage (def set to 31.00)
overcurrent (def set to 4.1a)
over power (def set to 35w)
max power (def set to 1.2ah)
max energy (def set to 2.2wh)
kgriff5667 is offline   Reply With Quote
power
