06-19-2016, 02:23 PM
Shore Power Connection
We took our maiden trip in our "new to us" Flagstaff 2011 Microlite 18RK this weekend, and everything went off without a hitch until it was time to leave the campground. The last thing I went to do was to disconnect the shore power connection only to find one of the prongs had melted in place! In the process of trying to get the plug off, I pulled out two of the cheap screws that Forest River used to install the outlet, in my opinion that should have been through bolted. Those small screws strip out of the fiberglass way too easily! Anyway, the melted connection is a bigger concern. It's bad enough that I need a new cord now and of course there is no place open on Sunday here that sells them. That cord was plugged in for the last two weeks at home with no issues (A/C and Refrig. both on). The only difference at the campground was, we used the electric water heater in which I had recently installed a brand new element. I also used a coffee maker twice, but other than that no additional loads that I didn't have at home in the driveway. I don't know what caused this meltdown, anyone have any thoughts?
David
Port Orange, FL
06-19-2016, 02:43 PM
Campground pedestal outlets see considerably more abuse than outlets at home especially when people are leaving. Someone before you could have had an issue with their plug which resulted in arcing and damaged the female outlet in the pedestal. This in turn would create a high resistance connection when you plugged in and heat up the plug. Although it could be the fault of the supplied shore power cord, it is more likely a problem with the pedestal box.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
06-19-2016, 03:21 PM
The OP said his problem was at the female end of what i assume to be a Furrion detachable cord. That would indicate a loss of contact at the trailer mounted assembly, which he indicated he pulled loose from the sidewall trying to remove the cord. Not an issue at the pedestal.
I would suspect the cordsets female connector, or the trailer mounted male assembly, was just worn from use if it was original to the 2011 trailer. It doesn't take very much of a loose connection to cause heat build up.
06-19-2016, 03:26 PM
Check that all conductors are tight at\behind breaker panel. Of they are tight and no signs of damage to the cable, it was probably the pedestal. Cut plug off go to Lowe's match it up with a replacement. Carefully wire up new plug matching conductors to correct prongs.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
06-19-2016, 03:30 PM
Flybob, the pedestal at the campground was brand new, probably within the last couple of months, not to say it couldn't have had an issue. The male outlet on the camper still looks good, but there could be a loose wire connection I suppose. When I pulled it out, it has a white protective housing around the wire connections and it wasn't readily apparent how to expose them. I'm hoping it's just female end of the cord itself, and not in the camper. I will pick up a new cord tomorrow and when I plug it in, I will gradually add loads to it while checking it to see if it's heating up. If it's something in the camper itself, you'd think a breaker would have tripped.
06-19-2016, 03:48 PM
We have many threads here on this same matter. A lot of times the owner (which may have been the previous owner) fail to properly do the final twist of the cord at the RV. This fails to get a full connection between the cord female and RV male, and creates arcing.....which over time does enough damage to melt something, especially with high amp usage.....which you stated you used the air conditioner (12-16 amps) and electric water heater (12 amps) who have 24-28 amps combined just right there of a 30 amp connection. Anything loose is not going to be good.
Also we have seen several instances where people fail to make sure their pedestal breaker is turned off before attaching/detaching the RV cord. This also allows arcing at the connection at the RV if this is where you connect last..... which again damages the cord and/or RV outlet.
Always make sure the pedestal breaker is off, before attaching or detaching your RV power cord.
2011 Flagstaff 831 RLBSS
06-19-2016, 03:57 PM
I have a question for you after rereading your OP. You said you only ran the air conditioner and fridge while plugged in at home. Can I ask what kind of outlet you were plugged into at your house? Was it a dedicated 30 amp outlet, or perhaps a 15 amp house outlet using an adapter?
Also here is a FAQ from a manufacturer of RV power cords that I should have added to my initial post. It may help:
https://conntek.wordpress.com/2014/0...ing-acting-up/
06-19-2016, 04:05 PM
I guess I'm guilty as charged, I'm plugging into a 20 amp circuit with an adapter. So I guess the next thing you are going to tell me is I damaged the cord end by doing this?
06-19-2016, 04:20 PM
Not necessarily, but when you do plug into the 20 amp outlet (which is something else I was going to touch on for a different reason though), are you connecting/disconnecting the cord at the RV while plugged into the 20 amp outlet?
This is another problem in itself, since most people who attach cords to their houses, do not actually run inside their house and flip the circuit breaker off when connecting/disconnecting....or go inside the RV and flip the main breaker off (which would also solve the problem somewhat).
Since the converter, microwave clock, television standby all require some 120 volt AC power...... when you connect to shore power you will get an instant power draw because of these items..... which is also what causes the arcing if the connections are not tight....and you also get a little arcing just from connecting either at the RV, or at the camp/house outlet depending on which one you do last at the final connection.
It's a little different than just connecting an extension cord at your house to say use a light, drill, electric weedeater. Since these items have on/off switches, there is no instantaneous power draw when connecting these to an extension cord, and thus no arcing. Your RV is different as mentioned above, and you do have items that will instantly draw power when connecting...or are still drawing power when disconnecting power cords if the circuit breakers are still on.
This is why you want to make all firm connections without power.....then turn the power on with a circuit breaker...either your house or the RV's...or both if you want to get really safe. You also do the same before disconnecting.
You can think of it like a water hose, and what happens when you try to hook or unhook a hose with water pressure still applied.
BTW, welcome to the forums which I also should have acknowledged in my initial post.
07-25-2016, 02:03 PM
2015 Solera 24R Power Inlet Burnt Up
I was camping in My 2015 Solera 24R with the AC running and convection oven on for about 20 minutes. The connection between my Furrion power cable connector and the Solera shore power inlet over heated. The shore power inlet plug burnt internally on the power leg. The power cord plug also burnt and melted on the power leg. The pedestal breaker finally opened after the power leg insulation about 2 inches outside of the shore power inlet cover melted and arched to the bare copper ground wire in the coach wall.
It appears that the set screws on the shore power inlet wire connections were not tight or torqued to specification at the Forrest River factory. The only set screw that was tight was the bare ground wire set screw in the inlet. The neutral wire was loose and the power leg connection inside the shore power inlet was melted and partially vaporized.
There was about 15 inches of excess 12 gauge orange romex inside the coach wall which allowed me to easily replace the shore inlet with a new part (from Camping World) and I also installed a new female 30 Amp Connector Retrofit Kit on the power cordset.
You may want to inspect the set screws in your shore power inlet to set if they are tight. You can easily unscrew the screws through the inlet and dismantle the back of the inlet box to check the torgue on the connection wires.
08-04-2016, 01:26 PM
Please excuse my semi-hijack of the thread, but I have looked, in vain, all over the forums for the specific subject.
My new 26fkws behaves well.....except for that #&@$%* twist-on power cord.
The idiot that replaced hardwired cords with this POS needs to be ......
From day one, we have had to "play" with the cord to get a connection.
Used to be...just pull up and plug in.
Now, I haul out the plug, plug into the (turned off) post, attach/twist/screw the cord in and then communicate with wife, through the window, to see if the microwave light is on.
....diddle,diddle....WAIT, it's on.....no....it's off....on, no....off....
(for the microsoft helpline folks.....yes, everything was done right, and it's plugged in)
(I can just imagine the arcing going on in the plug)
Took it to the dealer. He fussed for a couple days. Got it back with the TT connection rotated 90 degrees, but no improvement in operation.
Why, oh WHY did the factory fix what wasn't broke ??
2014 King Ranch Ecoboost Screw, 3.73.....2019 Palamino 27RLSS (customized)
Retired AF Mustang.....Picker always looking to jam.
08-04-2016, 02:46 PM
You have the Furrion power cord and plug?
I think I'd just invest in a good marine wall mount plug and cord mount receptacle. However, I know it's frustrating to have to deal with it on a brand new unit.
You could always take it back to the dealer and have them futz with it again. Maybe they'd get the message and just replace it.
Gotta go campin!
08-05-2016, 10:31 AM
I burnt mine up doing exactly that. lesson learned and installed dedicated 30 amp .
MARINOS
2015 PRIME TIME AVENGER 28 DBS
2016 GMC SIERRA DENALI 2500 HD
08-05-2016, 09:57 PM
When you attach the cord, the microwave light should not be on. Because the pedestal switch or the 30 (?) amp master breaker inside should be off so there is no power at the cord when you connect. This prevents arcing and wire/plug damage. Once connected, then turn on the pedestal or the inside master breaker. It should then be connected. If not, then something may be amiss at the connection point or even somewhere else in the line that you think is at the connection point but it isn't (such as a loose wire within the cord that also gets jiggled around when you twist and turn the connection).
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
08-05-2016, 10:08 PM
....uh, yeah....
Correct.....but it ain't.....that's why I posted.
> If not, then something may be amiss at the connection point...
ya think ?
>.... or even somewhere else in the line that you think is at the connection point but it isn't (such as a loose wire within the cord that also gets jiggled around when you twist and turn the connection).
I have disassembled the fem end and verified the connections.
I want the HARD WIRED cord that the whole world had until a couple years ago.
08-05-2016, 10:12 PM
Glad you have it all figured out. I mistakenly thought you were looking for assistance from the forum.
08-06-2016, 04:15 PM
I also mistakenly thought he was looking for help.
Gotta go campin!
08-07-2016, 12:00 AM
My apologies....to you, BR, and the rest.
It was more of a rant than a request for aid.
This was the wrong place for it, and I should not have done it.
I guess, if I had a question, it would be:
"Does anyone have any idea why manufacturers abandoned a perfectly good hard wired cord and went for the 'push/twist/screw' of a separate cord ? "
