Old 08-14-2015, 08:13 PM   #1
Shore power out does not go to battery
Just noticed this as TT is in driveway plugged in. Had a storm and lost power so went out to the TT to see about cooking dinner in there. No lights, no monitor...nothing. So I hooked up the truck, just to use battery to see. Had running lights on TT but nothing inside. Once the shore power came back on, everything worked fine and the monitor shows the battery as full charge.
I know nothing about these so I am sure I'm missing something but what might that be?
2016 Rockwood Signature Ultra Lite 8329SS
2004 Dodge Ram 3500 (Sterling) Auto w/built trans, 4X4 Quad Cab 5.9L Cummins
mikemc53 is offline   Reply With Quote
Old 08-14-2015, 08:23 PM   #2
Flybob's Avatar
Could be lots of things.
The battery will drain and die ( parasitic drain) if not charged periodically
Many TV with trailer packages have the wiring for the 12V aux power to the TT installed as part of the tow package, but they do not put the fuse or protection relay in the fuse box. Some have these items in a bag in the glove box. If they are installed, the relay will shot off the 12V aux power ( to charge battery or run interior lights) unless vehicle is running. This is to prevent killing the TV battery when parked. Check the fuse box for Trailer aux fuse and relay. If the battery is very dead and you plug in to shore power, you could blow the two 30-40A protection fuses in the converter ( trying to charge a dead battery). Check them ( usually orange).
You may also have a battery shut off switch that is off disconnecting the battery.
If you are storing TT you will need to
1. Add a battery tender to keep battery charged
or
2. keep TT plugged in ( if you do this check battery water monthly
or
3. add a battery shut off switch .
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-14-2015, 08:33 PM   #3
Batts-toy's Avatar
Lights and control circuits for the Fridge (on propane) and Heater (on propane) are powered by the coach batteries provided the coach batteries are charged up. Anything that has been connected to an inverter (changes 12 volts DC to 110 volt AC) for 110 volt will run off the batteries as well through the inverter. Other than that all 110 volt appliances have to be powered by your 30 or 50 amp power cord. Also when your TT is plugged in to the house (or power post at a camp ground) the TT's Converter converts 110 volt AC to 12 volt DC and charges the coach batteries. Most trailers do not come with an inverter but all are equipped with a converter.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 08-14-2015, 08:35 PM   #4
rclogg's Avatar
Mike I live right around the corner, Chesterfield we lost power too. Was your battery disconnect on. This would take out all battery devices.
'14 Cummins Dually Aisin 4.10
'07 FR Cardinal LE 30RK
'03 Cummins Dually 45RF
'01 Exiss 300MT Weekender
A wife and two dogs, isn't that enough?
rclogg is offline   Reply With Quote
Old 08-14-2015, 08:44 PM   #5
gashog's Avatar
2X disconnect is likely on. been there done that...
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 08-14-2015, 09:41 PM   #6
Oh, yea. Now I can say...been there - done that.
I had completely forgotten that I turned the disconnect off a couple of weeks ago - don't ask, it's a long story. Not only did I forget that I turned it off, I forgot that there was a disconnect.
Turned it on and all back to normal.
I am definitely not getting brighter with time.
Thanks gang!
Old 08-14-2015, 09:58 PM   #7
gashog's Avatar
I like happy endings
battery, power
